Changing entities exposed to HomeKit
Hello, I have a Spa pool which I have working within Home Assistant and it works great, but when I expose the same switches inside HomeKit, I receive multiple switches for the same button.
The Home Assistant entity for the pumps is a fan which I believe it causing the issues here.
Is there a way to create a single toggle button inside Home Assistant which can mimic the state of the fan on/off entity (without speeds and other states) so that I can expose this single switch to HomeKit for each pump? I have an image below showing that inside Home Assistant I have one toggle switch for each pump, but then inside HomeKit each pump is exposed as 4 switches.
