I’m trying to add a configuration option to the mitemp_bt custom component. What I would like to achieve is that the user can couple a mac-address to a custom sensor_name in the configuration.yaml and, if specified, that the ‘entity_id’ is changed, based on this input. So, if a name is specified, it uses the specified name, if not, it uses the mac address as default name.
I managed to change the friendly_name attribute in this way, but I also would like to change the entity_id, while keeping the unique_id as it was. People have asked for this function, but I can’t figure out how to change the entity_id, without changing the unique_id as well (which is basically creating a new sensor, while the old one becomes unavailable).
To me, it sound better is only the entity_id is being changed, but I can’t figure out how.
I tried to change the object_id in the class of the sensor like this.
class TemperatureSensor(Entity):
"""Representation of a sensor."""
def __init__(self, config, mac):
"Initialize the sensor."""
self._state = None
self._sensor_name = sensor_name(config, mac)
self._object_id = "mi_t_" + self._sensor_name
self._unique_id = "t_" + mac
self._device_state_attributes = {}
@property
def name(self):
"""Return the name of the sensor."""
return "Temperature {}".format(self._sensor_name)
@property
def object_id(self):
"""Return object id."""
return self._object_id
Unfortunately, only the friendly_name changes in this way, not the entity_id.
