If I try to change the name of my device thats currently called “bed4” to “bed-pressure”, then when I try install and update wirelessly, it tries to connect (and fail) to bed-pressure.local
Is there anyway in the YAML file to specify the IP directly? I do not want to have to remove the device form where it is to update it. But I do want to change the name
In my experience, and I am no expert, the name: parameter must be the same as the yaml filename.
I am not sure what you are saying here.
Can you put the name back to the original and do an OTA update then?
If you can reestablish connection with the device, then you won’t have to remove it to flash again.
In future devices, I recommend the web server lines above if you have the storage space in the device. Also add:
# Get the WiFi details
text_sensor:
- platform: wifi_info
ip_address:
name: ${device_name} IP Address
ssid:
mac_address:
name: ${device_name} Mac Address
- platform: wifi_signal
name: ${device_name} WiFi Signal Sensor
update_interval: 60s
Oh, at the top of my yaml file:
substitutions:
device_name: counterlight
This code creates these entities from my device:
text_sensor.counterlight_IP_Address
sensor.counterlight_WiFi_Signal_Sensor
sensor.counterlight_WiFi level
