Having problems setting up ZHA with one of my sensors and was told to try zigbee2mqtt. But I’m missing something again… Deleted ZHA. Restarted HA. Installed Mosquitto broker add on, made user for mqtt. Installed MQTT integration and used the new user I made from Mosquitto instructions. Installed zigbee2mqtt addon and nothing works. I’m using a tube-zb usb dongle and change port for it. Added the frontend and experimental lines. Added login info. Still getting errors and web ui does not work. Here is the info from each of them. What am I missing???
mosquitto
logins: []
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
zigbee2mqtt
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto
user: mqtt
password: xxxxxxxx
serial:
port: tcp://tube_zb_gw_cc2652p2.local:6638
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental:
new_api: true
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
zigbee2mqtt logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[21:41:22] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[21:41:23] INFO: MQTT available, fetching server detail ...
[21:41:24] INFO: Previous config file found, checking backup
[21:41:24] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[21:41:24] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:41:25] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Zigbee2MQTT:error 2021-11-21 21:41:32: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-11-21 21:41:32: Failed to start zigbee
Zigbee2MQTT:error 2021-11-21 21:41:32: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-11-21 21:41:32: Exiting...
Zigbee2MQTT:error 2021-11-21 21:41:32: Error: Error while opening socket
at Socket.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:198:24)
at Socket.emit (events.js:412:35)
at emitErrorNT (internal/streams/destroy.js:106:8)
at emitErrorCloseNT (internal/streams/destroy.js:74:3)
at processTicksAndRejections (internal/process/task_queues.js:82:21)
[21:41:32] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
