Changing HA IP4 from cli doesn't work
I try changing my HA IP with below command from CLI:
network update enp0s18 --ipv4-address 192.168.1.25/24
Command completed successfully, but the IP doesn’t change.
And same issue with another “method”:
ha > login
set ipv4.addresses 192.168.1.25/24
Can someone help me how to change the IP?
Assuming it’s IP isn’t fixed in your DHCP have you tried restarting the device after changing the IP?
Sorry, I’m not that good in networking. I’m running HA from under Proxmox VM, so I assume you mean if I restarted the Prox VM, after getting the successful response?
