This worked fine with my old RP4 installation but the password is different with the new one and I don’t seem able to change it, because when I enter the new password it looses connection with the mosquitto broker.
I can’t change the password on my devices, because, apart from the fact I have a lot of them, some of them are in France and I am in the UK.
Did you looked at the configuration parameters (username/password) defined for the mosquitto broker (see parameters → add-on’s → configuration) ?.. MQTT integration and MQTT add-on should be obviously in sync from a username/password point of view…
But when I try to change the password in settings to the same value it looses the connection to the broker and I have to change this password back to the default.
Im reading it too, but the documentation is incorrect. At the bottom it says:
" The /share folder can be accessed via SMB, or on the host filesystem under /usr/share/hassio/share."
But there is no such folder, hence no file to edit.
All my devices have a username and password for the mqtt connection, now i have the broker add-on, but i am unabl to change the username and password to that specific username and password.
I guess the solution is to set the old password of user homeassistant not directly in the Mosquitto broker - addon. There you can set only new users and passwords apart of the user homeassistant…
