I hacked an Aqara Door sensor to check the water level in my pool. When low, it triggers a valve to turn on to fill the pool.
My question is: since I am using a door sensor, the states are OPEN and CLOSED. I would like to rename those states so that OPEN displays FULL and CLOSED displays LOW.
Also, on the hose valve (a wifi B-Hyve hose timer), I would like on to show as FILLING and OFF can display OFF.
Is that possible in HA? If so, I don’t know how to change state labels.
These are the available device classes for the binary sensor domain that change the translated state value in the frontend: Binary sensor - Home Assistant
