So… I decided to change my HA password. Seemed like a good idea at the time.
I use Owntracks via HTTP (but please read on even if you don’t, I am sure someone can help me with this) and I restrict login attempts to 5. I’m guessing you’re ahead of me here, but I hadn’t considered that Owntracks would cause the ban before I had time to change the passwords on the two phones that use it.
I have had the HA ban notification for my IP and whilst I can still access it (I presume) because my PC was already logged on, how can I reset the IP ban?
Is it enough to remove the ban in my config and then restart HA and then reinstate it?
Err… I stopped Samba and SSH in a fit of panic last night after reading yet another thread about hacking, which is also why I changed my password this morning.
BIG mistake!
As far as I can tell and unless you know something else, my only option is a complete rebuild.
I am definitely developing a Love/Hate relationship with HA.
Is there no way to put the SD card into my PC and edit the files there?
(I almost certainly expect the answer to be “no” but I thought I’d ask.)
If you are using keys for authentication you should be able to connect on port 22222 (I think) It’s a dev mode ssh… might need to search docs to find it.
Can you connect from a non-banned IP address like a 4G or a neighbours connection?
I think hassio is actually quite brilliant given its objectives but I really do believe the whole security thing should have been tidied up first. It’s kinda cruel to offer a simplified solution to people not knowledgeable enough to make sure they are using it ‘properly’ (and I count myself just about inside that subset of people too, when it comes to network security).
