Changing Proxy IP with Docker-Compose and Traefik
Hello all,
I’m having some issues setting up Home Assistant with Docker-Compose & Traefik. I have everything working including Home Assistant container being network mode host. The only problem I face now is that my proxy changes IP addresses once in a while, so when I restart Home Assistant, I have to whitelist the proxy anytime it changes. Does anyone have a solution to this? Here is my Home Assistant configuration and Docker Compose file.
configuration.yaml
# Set up for use with Traefik reverse proxy.
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 192.168.192.2 # Add the IP address of the proxy server
    - 192.168.224.3
docker-compose.yml
version: '3'
services:
  homeassistant:
    container_name: homeassistant
    image: ghcr.io/home-assistant/home-assistant:stable
    volumes:
      - ./homeassistant/config:/config
      - /etc/localtime:/etc/localtime:ro
    restart: unless-stopped
    privileged: true
    network_mode: host
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.hahttp.rule=Host(`DOMAIN.com`)"
      - "traefik.http.routers.ha.rule=Host(`DOMAIN.com`)"
      - "traefik.http.routers.ha.tls=true"
      - "traefik.http.routers.ha.tls.certresolver=le"
      - "traefik.http.routers.ha.tls.domains[0].main=DOMAIN.com"
      - "traefik.http.services.homeassistant.loadbalancer.server.port=8123"
  traefik:
    container_name: traefik
    # The official v2 Traefik docker image
    image: traefik:v2.8
    command:
      - "--api.dashboard=true"
      - "--api.insecure=true"
      - "--accesslog=true"
      - "--providers.docker"
      - "--providers.docker.exposedbydefault=false"
      - "--entryPoints.web.address=:80"
      - "--entrypoints.websecure.address=:443"
      - "--certificatesresolvers.le.acme.tlschallenge=true"
      - "--certificatesresolvers.le.acme.email=EMAIL"
      - "--certificatesresolvers.le.acme.storage=/letsencrypt/acme.json"
    ports:
      - 80:80
      - 8080:8080
      - 443:443
    volumes:
      - "/var/run/docker.sock:/var/run/docker.sock:ro"
      - "./letsencrypt:/letsencrypt"
    extra_hosts:
      - host.docker.internal:172.17.0.1
As you can see in my Home Assistant configuration, those are the two IP addresses primarily used as a proxy, but I feel like that is not how it should be.
I’m having the same problem.
Any answers yet ?
