I have a switch that is used to flash an LED segment. I would like this button to act as a momentary switch and change the state of the icon back to off after a few seconds.
I have the self.listen_state to get the state when pushed, I just can’t figure out what the self.set_state or other command would be to set the state back to off so the icon state would change to off.
How could I do this?
Is there something other than a widget_type: switch I should be using.
If you’re talking about HADashboard V1 the ‘scene’ data-view has a data-ontime parameter that sets the time out of the momentary switch look and feel. The scene can be switch.ledsegment state: on. Then have an automation that on x seconds turns switch.ledsegment off or whatever you are trying to accomplish.
Similar deal with HADashboard V2. Just use a ‘scene’ widget_type and do the same as above. Not sure if there is a time out value yet but it will trigger off after about a second.
i have a bunch of input booleans myself that i use as buttons.
i use listen_state(self.callback,“your.entity”,state=“on”) to listen to the boolean, in the callback i use:
def calback(...)
do some stuff
self.turn_off(entity)
that way the action is done when i turn the boolean on and it goes off afterwards.
