I originally posted this here, but I figured this may be bigger than a custom component, so let’s start something new shall we?
I’ve got a challenge on my hands.
It may not be challenging for you beautiful people, but hey ho, that’s why I’m here seeking brains that aren’t as frazzled as mine.
Background
I’ve tried doing what I’m about to describe using a picture-entity card - got most of the way there with separate images, but for some I get a spinner of death after a certain number of entity state images (I think it was after 8…).
So two options to overcome this - a: card-mod… or b: custom button card c: I’m open to suggestions!
Here I am trying out the custom button card solution and it’s getting too late for me to get it working on own.
My challenges (to me and) to you!
I’m trying to create a card that displays a picture of my car - as an SVG image. (The easy part)
I’m trying to update the fill colour of various paths (identified by class tags) based on the state of a sensor entity [and to make sure we give sensor’s attribute’s some love - a sensor’s attribute ‘state’ too!]. (my JavaScript is weak… and googling says I’m the only one mad enough to try it in lovelace and the custom components I’ve got… or I’m using the wrong search terms).
Each item is on a different sensor: eg, front right door lock = sensor.car_front_door_right, front left window = sensor.car_front_left_window
I’m not sure where to put the JavaScript so it’ll update (I’ve got a hunch, but am I right?) the one image from multiple sensors…
Below is where I got to so far, I’ll carry on hacking away
YAML card:
- type: 'custom:button-card'
# template:
# - card_generic_swap
entity: sensor.ml71nym_car
show_entity_picture: true
entity_picture: /local/EQA/EQA-Merc-Top-RHD.svg
# extra_styles: >
# let
show_icon: false
show_label: false
show_name: false
show_state: false
styles:
card:
- height: 190px
- border-radius: 14px
- box-shadow: none
# - font-size: 30px
- text-align: left
- cursor: default
entity_picture:
- width: 95%
- transform: >
if (states['sensor.front_right_door'].state == "Open")
return "
.theClassOfThePathInTheSVG {
filter: hue-rotate(180deg);
return "
return "
# - color: [] # >
# var svgHolder = document.querySelector('svg#carOutline');
# svgHolder.onload = function () {
# var svgDocument = svgHolder.contentDocument;
# var style = svgDocument.createElementNS("http://www.w3.org/2000/svg", "style");
# // Now (ab)use the @import directive to load make the browser load our css // '@import url("/css/your-dynamic-css.css");'; or..
# style.textContent = "<style>
# .bvl-icon-lamp-outline{
# fill:rgba(var(--rgb-primary-text-color), 0.7);
# </style>";
# var svgElem = svgDocument.querySelector('svg');
# svgElem.insertBefore(style, svgElem.firstChild);
img_cell:
- height: 100%
# custom_fields:
Sample of SVG Image with sample classes: carOutline, doorHandle_rearLeft, doorHandle_rearRight,
doorHandle_frontLeft,doorHandle_frontRight … can be found here on dropbox.
Check it out
