We use the Android TV Remote integration (Android TV Remote - Home Assistant) as our dog ate our remote. For simplicity’s sake, I recreated the same remote interface. Unfortunately ADB access is not possible. Considering that almost everything is customizable in HA, I thought it must be possible to rename the Application ID (e.g. com.google.android.tvlauncher) to a more legible one by providing a list and replacing the values.
I know this might be a silly thing, but I know if its bothering me, its bothering someone else.
I don’t want to seem like I am fighting, but this seems like an arbitrary limitation within HA. I can specify a variable in python and PowerShell to replace basic text wherever it is called, can this not be done in HA? I will say I am very new to HA and Linux overall, but I have quite a bit of knowledge in windows systems.
It’s not a HA limitation it’s a limit of how apps are built It would work the same on Windows as well. The item you’re looking for is compiled I the actual executable and in the app manifest. It’s designed to be immutable for a specific app for a reason.
You basically are saying the equivalent of well ok I know your name is Joe but I need you to put whiteout on your birth certificate and call yourself Ron for me. K?
I know this is a bit older now. But what I’m thinking, there has to be a way of creating a table and saying “if I see this, then change it to that”. More like saying “I know your name is Joseph, but I’m gonna call you Joe”
I know this topic is quite old now, but if you want to display app name (e.g. YouTube) instead of app package name (e.g. com.google.android.youtube.tv) on Media control card you can do this with media_player.template integration. You can install it with HACS or manually.
The integration allows to set custom media player title via title_template configuration variable. You can conditionally set desired app name based on app package name exposed by Android TV remote media player.
Below is a code snippet you can add to your configuration.yaml file. Just change media_player.android_tv to your Android TV media player entity and add conditions for other Android apps installed on your TV in title_template. You can also configure other variables based on your needs.
After adding this to your configuration.yaml file and restarting Home Asisstant you should have media_player.android_tv_template entity, that shows currently opened app name on Media control card.
If anyone still has this problem it looks like there is an easier way to do this by configuring application list and it doesn’t require any additional integrations.
Here is my step by step tutorial how to do this:
Go to Settings > Devices & services > Android TV Remote
Click Configure next to device for which you want to set application names.
In the pop up window select Add new from Configure Applications List and click Submit.
Now you should get another pop up window where you specify:
Application name - the app name that you want to be displayed (eg. YouTube)
Application icon - optional URL to app icon (will be visible in apps list after clicking Browse Media on your media player)
