Hi.
I wanted to ask if its possible to reverse the order of a reply.
Currently when the assistant is being asked to perform a task it will first do it and then reply that it is being done, that cause a problem when it is used to play music on the same speakers that are used by the assistant to reply. It will start playing the music and than reply that its being played, but the reply causes the music to stop, in this way, it is not possible to use the assistant in the same speakers that are used to play music…
if it will be reversed than it will first replay and than the music will start and keep playing.
Thanks!
