Changing the test colour - condiction on a sensor value
I just need a bit of help in finding my mistake. I would like the text to change colour depending on the value of the sensor. but I can’t see the mistake I have made, can you help
  • entity: select.octopus_import
    type: custom:multiple-entity-row
    name: Octopus Current Traff
    icon: mdi:television-off
    toggle: false
    show_state: false
    state_color: true
    entities:
      toggle: false
      .text-content:not(.info) {
      color:
      {% if is_state(‘sselect.octopus_import’, ‘day’) %}
      green
      {% elif is_state(‘select.octopus_import’, ‘cheap’) %}
      yellow
      {% elif is_state(‘select.octopus_import’, ‘max’) %}
      red
      {% endif %}
    • entity: select.octopus_export
      toggle: false
Please format your code properly - very difficult to read otherwise.
How to format your code in forum posts.
reformatted version
  - entity: select.octopus_import
    icon: mdi:electric-switch
    toggle: false
    show_state: false
    state_color: true
    entities:
        toggle: false
             color:
               {% if is_state('sselect.octopus_import', 'day') %}
                  green
                {% elif is_state('select.octopus_import', 'cheap') %}
                  yellow
                {% elif is_state('select.octopus_import', 'max') %}
                  red
              {% endif %}
      - entity: select.octopus_export
        toggle: false
