PA_Klaus
(Johan)
July 5, 2022, 10:16am
1
Good afternoon,
I am using GitHub - KoljaWindeler/ics: Integration that displays the next event of an ics link (support reoccuring events) intergration
I want my google mini to say the time and date of the appointment but if i do this:
{{ state_attr(‘sensor.ics_1’, ‘start’ ) }} i get: 2022-07-12 15:45:00+02:00
Hope someone can help me with this.
i want the following “15 uur 45” and “12-Juli” < dutch (English: “15 hour 45 minutes” “12-July”)
Troon
(Troon)
July 5, 2022, 10:35am
2
Plug this into Developer Tools / Templates and have a play:
{{ state_attr('sensor.ics_1', 'start' ) }}
{{ state_attr('sensor.ics_1', 'start' )|as_timestamp|timestamp_custom('%H uur %M', local=True, default=0) }}
{{ state_attr('sensor.ics_1', 'start' )|as_timestamp|timestamp_custom('%d-%B', local=True, default=0) }}
References: Templating - Home Assistant and datetime — Basic date and time types — Python 3.8.13 documentation .
Please format code snippets correctly in posts — if the forum software thinks it’s text, it substitutes “smart quotes” which mess up templates.
You can also use strftime() instead of using a timestamp conversion.
{{ (state_attr('sensor.ics_1', 'start')|as_datetime).strftime("%H uur %M") }}
{{ (state_attr('sensor.ics_1', 'start')|as_datetime).strftime("%-d-%B") }}
@Troon
Perfect works great thank you! Going to learn Python one of these days because its so cool!
With:
I get 12-July i want July (and other months) translated to dutch e.q. Julie
I was searching the net but my attempts with examples given i could not find the solution.
123
(Taras)
July 5, 2022, 9:33pm
5
{% set m = {
1: 'Januari',
2: 'Februari',
3: 'Maart',
4: 'April',
5: 'Mei',
6: 'Juni',
7: 'Juli',
8: 'Augustus',
9: 'September',
10: 'Oktober',
11: 'November',
12: 'December'
{% set dt = state_attr('sensor.ics_1', 'start') | as_datetime %}
{{ dt.hour }} uur {{ dt.minute }}
{{ dt.day }}-{{ m.get(dt.month, 'Unknown') }}
I copied the Dutch month names from an online source; you may need to correct any misspellings.
Here’s a screenshot of my test result:
Troon
(Troon)
July 6, 2022, 7:18am
6
Oh yes: the locale setting doesn’t do the translation for you, does it? That seems like a shortcoming in the system…
Thanks but if i run your code i get:
TypeError: float() argument must be a string or a number, not ‘datetime.datetime’
{% set m = {
1: 'Januari',
2: 'Februari',
3: 'Maart',
4: 'April',
5: 'Mei',
6: 'Juni',
7: 'Juli',
8: 'Augustus',
9: 'September',
10: 'Oktober',
11: 'November',
12: 'December'
With this it works perfect. i dont have allot of knowledge about python but i think
Must be in {{ }} of “” “” or ‘’ i tried some combinations but no luck…
{% set m = {
1: 'Januari',
2: 'Februari',
3: 'Maart',
4: 'April',
5: 'Mei',
6: 'Juni',
7: 'Juli',
8: 'Augustus',
9: 'September',
10: 'Oktober',
11: 'November',
12: 'December'
{% set dt = '2022-07-12 15:45:00+02:00' | as_datetime %}
123
(Taras)
July 7, 2022, 1:19pm
8
Not sure why you received that error.
As an experiment, copy-paste the following into the Template Editor and tell me what it reports:
{{ state_attr('sensor.ics_1', 'start') }}
{{ state_attr('sensor.ics_1', 'start') is string }}
123:
string
output is: (new date because of new calander item)
2022-07-09 08:00:00+02:00
False
i olso tried float and boolean but they where olso false
123
(Taras)
July 8, 2022, 12:42pm
10
According to the results of the test, the start attribute’s value is not considered to be a string. In other words, it’s considered to be a datetime object so there’s no need to use the as_datetime filter to convert it from string to datetime.
Try this version in the Template Editor:
{% set m = {
1: 'Januari',
2: 'Februari',
3: 'Maart',
4: 'April',
5: 'Mei',
6: 'Juni',
7: 'Juli',
8: 'Augustus',
9: 'September',
10: 'Oktober',
11: 'November',
12: 'December'
{% set dt = state_attr('sensor.ics_1', 'start') %}
