I have my default text type for Amazon Polly to be text (so not SSML).
This is fine if I just want to output something over a Chromecast speaker using Text to Speak.
However, if I then want to use SSML in a script, how do i do this on a case by case basis? If I start using SSML, the Chromecast will read it literally… “speak hello slash speak” for example.
On the flip side, if I change the default text type to be SSML, my scripts work fine, but then I can not use a simple Text to Speak to Chromecast as it complains its not valid SSML.
Thanks in advance.
UPDATE : I guess what i actually need, is two different TTS profiles. However, how do I achieve this. Whenever i set up two, they ignore the “type” settings defined and just seem to always use “ssml”, and also, how can I set which media player “TTS” box using which profile?
