Changing units on the front-end breaks calculations - what am I doing wrong?
If I change the units on a gauge showing a temperature, a calculation using the gauge’s value uses the new value from the changed display without respect for the units. What am I doing wrong? The sensor and template sensor definitions are also included.
Change the inlet temperature units to F, note the Delta T gauge:
from configuration.yaml…
 - name: "cx_delta_t"
      unique_id:  cx_delta_t
      state_class: measurement
      unit_of_measurement: °C"
      state: >
        {% set hp_outlet_temp = states('sensor.cx50_outlet_water_temp') | float %}
        {% set hp_inlet_temp = states('sensor.cx50_inlet_water_temp') | float %}
        {% set hp_delta_t = hp_outlet_temp - hp_inlet_temp | float %}
        {{ hp_delta_t | round(1, default=0) }}
from modbus.yaml...
    - name: "CX50 Outlet Water Temp"
      unique_id: "cx50_outlet_water_temp"
      device_class: temperature
      unit_of_measurement: "°C"
      scale: 0.1
      input_type: holding
      address: 205
      slave: 1
      precision: 1
    - name: "CX50 Inlet Water Temp"
      unique_id: "cx50_inlet_water_temp"
      scale: 0.1
      input_type: holding
      address: 281
      slave: 1
      precision: 1
this is the display with the default units set for the gauges
