I’m trying to setup Thread and using a “Eve Energy” over Matter/Thread.
Setup:
Home Assistant OS 13.1
Core 2024.9.2
HW: Raspberry Pi 4
- Sky Connect (latest Firmware)
I’m having only 1 Thread-Network: HomeAssistant. I made it my preferred Netword. Share the Cred with my iPhone.
When adding the Matter-Device, it stops after many seconds with “FAILED”
Debug of OTBR:
[20:30:17] INFO: The otbr-web is disabled.
s6-rc: info: service mdns: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
[20:30:18] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Aug 26 2024 16:52:48) starting
Add-on: OpenThread Border Router
OpenThread Border Router add-on
Add-on version: 2.10.0
You are running the latest version of this add-on.
System: Home Assistant OS 13.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.9.2
Home Assistant Supervisor: 2024.09.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[20:30:20] INFO: Checking /dev/ttyUSB0 identifying SkyConnect v1.0 from Nabu Casa.
[20:30:20] INFO: Starting universal-silabs-flasher with /dev/ttyUSB0
2024-09-19 20:30:22.227 homeassistant universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.4.3', ezsp_version=None, ot_rcp_version='SL-OPENTHREAD/2.4.0.0_GitHub-7074a43e4' (2.4.0.0), cpc_version=None, fw_type=<FirmwareImageType.OT_RCP: 'ot-rcp'>, baudrate=460800)
2024-09-19 20:30:22.228 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-09-19 20:30:24.247 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
2024-09-19 20:30:25.380 homeassistant universal_silabs_flasher.flasher INFO Detected ApplicationType.SPINEL, version 'SL-OPENTHREAD/2.4.0.0_GitHub-7074a43e4' (2.4.0.0) at 460800 baudrate (bootloader baudrate None)
2024-09-19 20:30:25.381 homeassistant universal_silabs_flasher.flash INFO Firmware version 'SL-OPENTHREAD/2.4.0.0_GitHub-7074a43e4' (2.4.0.0) is flashed, not re-installing
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service otbr-agent: starting
[20:30:26] INFO: Setup OTBR firewall...
[20:30:27] INFO: Starting otbr-agent...
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
s6-rc: info: service otbr-agent-configure: starting
Done
s6-rc: info: service otbr-agent-configure successfully started
[20:30:28] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[NOTE]-AGENT---: Running 0.3.0-b66cabf-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/ttyUSB0?uart-baudrate=460800&uart-flow-control
[NOTE]-AGENT---: Radio URL: trel://end0
[NOTE]-ILS-----: Infra link selected: end0
49d.17:23:50.692 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.052 [N] RoutingManager: BR ULA prefix: fd01:3b85:19d::/48 (loaded)
00:00:00.052 [N] RoutingManager: Local on-link prefix: fd49:e125:7b71:6e0a::/64
00:00:00.089 [N] Mle-----------: Role disabled -> detached
00:00:00.121 [N] P-Netif-------: Changing interface state to up.
00:00:00.158 [W] P-Netif-------: Failed to process request#2: No such process
00:00:00.159 [W] P-Netif-------: Failed to process request#6: No such process
00:00:00.373 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:00.577 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:00.811 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.033 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.274 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.466 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.694 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:01.932 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:02.163 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:02.421 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:02.642 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:02.872 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.091 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.297 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.505 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:03.750 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.004 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.231 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.426 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.653 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:04.872 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:05.125 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:07.735 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:08.723 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:09.773 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:09.992 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:15.068 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:19.972 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:25.327 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:26.206 [N] Mle-----------: RLOC16 8c00 -> fffe
00:00:26.810 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:27.067 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:27.808 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:28.569 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:29.788 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:31.051 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:32.295 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:32.675 [W] P-RadioSpinel-: Handle transmit done failed: ChannelAccessFailure
00:00:33.311 [N] RouterTable---: Allocate router id 35
00:00:33.311 [N] Mle-----------: RLOC16 fffe -> 8c00
