Hello Smart people,
I am working on an IR remote controller using Nodemcu board, IR led and some wires
Used ESP home to program the node and Smart IR addon to integrate the board as media player in Home Assistant, everything works great and I can switch TV on/off, change volume, change channel, change source, mute, etc.
I records the IR code (using the same Nodemcu) and for channels I have recorded from 0-9 just like the normal remote controller
The problem:
I am using Home Assistant play media service to change channels as it can combine all the possible numbers (0-99) and far beyond, but I struggle with numbers like 11, 22, 33, etc. it just send them as one number (11 is 1, 22 is 2)
I think the problem is likely about timing and TV translation but canβt figure it out any help should be appreciated
