I have been working with the team over at EVCC. They have a great solution to control the charge of your EV. They support several chargers and cars as well as different solar systems (meteors, inverters etc).
They now have support for Tesla Wall Charger (testing). It works quite well and removes lots of work for automating. HA also has an add-on for EVCC but that does not run the version having support for TWC yet since it is in testing and they are now asking for more testers before they add it into the product.
on my quest to find something that controls charging of my PV battery, car batter and at a later point in time also my heat pump I have now stumbled on EVCC.
I am currently working on the initial config, and am unsure what to do about the Wallbox. My Heidelberg Energy Control is a “dumb” wallbox that cannot be controlled at all, so I do all my automation through the Tesla Custom integration…but how do I teach EVCC that?
And if we check the actual charging window the evcc integration does not switch to cheapest window charging, but charges in 6A current until car battery in defined capacity.
From 01:00 o' clock the spot price would be near 0 c as in the evening it was around 5 c. We did have plenty of time to charge with 11 kW as the plan departure time was 07:00.
So in my case the evcc optimized the most priciest time slot of the charging window.
