Now with the lovely new Opower integration, I am able to pull my power usage.
I would like to correlate it with temperature & humidity as a line graph.
chart_type: line
period: day
type: statistics-graph
entities:
- opower:elec_secret_special_magic_acct_no_energy_consumption
- sensor.hamd_temperature
title: Temp to Power Usage
stat_types:
- state
- mean
The sensor.hamd_temperature is the mean temperature of all the temperature sensors in the property.
The above code looks kind of like it (see attached), but the Y scales are obviously not proper. I need a way to set both lines (or three if including humidity), to start at the same spot or closer to each other.
I would say you need to use a more powerful charting tool - although it might be possible using the built-in line chart.
One of the best charting integrations is the apexcharts card (HACS). It takes a bit of work but worth it and the documentation and threads here in the community are extensive.
