I’m trying to insert user-generated input text from a dashboard card to be included within a larger ChatGPT text prompt. The goal for the output is a unique bedtime story, with a user (my kids) inspired theme to be read back via ElevenLabs tts or the user (me as the parent).
I’m looking for help/recommendations on the best way to combine the base prompt text with the user-generated text for the full prompt to post via rest sensor platform to the resource https://mylocalhass/api/conversation/process (because service conversation.process via UI doesn’t return the response). The challenge is that payload in the rest sensor doesn’t allow templating.
The user-generated text is an input_text, the whole prompt is being stored in a template sensor, using the attributes to bypass the string length limitations of 255 char for states:
{{ states('input_text.story_prompt') }}
Result type: string
The theme of the story is the kids are going on a balloon ride to the ocean.
And then the template sensor:
template:
- sensor:
- name: "GPT Bedtime Story Prompt"
state: >
{{ this.attributes.story_prompt | default('null') }}
attributes:
full_prompt: >
I want you to write a bedtime story for my two kids. I want them to be part of the story. Their names are Jill and Jack. Include two lessons from Aesop's fables to be worked into and a part of the story. Do not mention Aesop's fables by name. Instead reference the lessons as a story their parents had told them. {{ states('input_text.story_prompt') }} The story should be as long as it would take 10 minutes for an adult to recite it.
story_prompt: >
gpt_json: >
'{ "text": "{{ this.attributes.full_prompt }}", "language": "en" }'
The response is solicited/stored in the following rest sensor:
- platform: rest
resource: https://mylocalhass/api/conversation/process
method: POST
name: GPT Bedtime Story Response
timeout: 45
scan_interval: 31557600
json_attributes_path: "$.response.speech.plain"
json_attributes:
- speech
headers:
Authorization: !secret gpt_test_token
Content-Type: application/json
value_template: "blah blah"
payload: >
{{ state_attr('sensor.gpt_bedtime_story_prompt','gpt_json') }}
Doing a homeassistant.update_entity on the above entity produces the following:
Logger: homeassistant.components.http.data_validator
Source: components/http/data_validator.py:60
Integration: HTTP (documentation, issues)
First occurred: 12:41:07 AM (2 occurrences)
Last logged: 9:56:04 AM
Invalid JSON received
Logger: homeassistant.components.rest.sensor
Source: components/rest/sensor.py:161
Integration: RESTful (documentation, issues)
JSON result was not a dictionary or list with 0th element a dictionary
All goes well if I replace payload with the actual json.
'{ "text": "I want you to write a bed time story for my two kids. I want them to be part of the story. Their names are Jill and Jack. Include two lessons from Aesop's fables to be worked into and apart of the story. Do not mention Aesop's fables by name. Instead reference the lessons as a story their parents had told them. The theme of the story is the kids are going on a balloon ride to the ocean. The story should be as long as it would take 10 minutes for an adult to recite it.", "language": "en" }'
Thoughts suggestions? What trivial thing am I missing? Thanks in advance!
I’m using the ha_chatgpt custom component (to make use of gpt3.5-turbo, which official doesn’t support yet) and elevenlabs_tts for read back.
