I’d like to enhance my presence detection with some iBeacons. I currently use wi-fi and owntracks for detection of home and away. I’d like to add iBeacons to improve owntracks detection.
Are there any ibeacons for sale on aliexpress or banggood / gearbest etc that are cheap. I was surprised how expensive they were when i tried to find some online.
The best “beacon” I have found is my Xiaomi Mi Band 2. The upside of this vs a beacon is that the battery lasts about a month, can be recharged and since it’s on my wrist its always on me. Oh, and it is about 20 bucks.
There is also this module, it has two switches which i think can be programmed and setup using only am app on your phone, but I’m not 100% sure. I’m not sure if the cheaper first chip can do the same of you short two of the pins.
~ $5 USD
NRF51822 2V-3.3V Bluetooth 4.0 Wireless Module For iBeacon Base Station Intelligent Control System Beacon BLE Module 4MA W/ Case
I’m using an HM-10 module which is really cheap, and can be programmed to become an iBeacon. You just need to add a case and power supply.
Just be aware that there are many clones available which may or may not work as expected.
I use the HappyBubbles Presence Server for deciding where I am. Proximity information is being fed by a Node-Red pipeline running on a couple of Raspberry Pi W Zero’s placed throughout the house which all execute a continuous BLE-Scan for the MAC of my Mi Band.
With this, my house can know:
whether I am at home or not
In which room I am
For “home/away” detection I actually use something else, I currently use this setup for the room-tracking functionality.
What’s the range on these? I’d like to set up with my phone and OwnTracks, and my concern is whether the range is short enough. I’d like to be able to discriminate room-by-room, not just “at home”. Will they work for that? Price seems hard to beat.
The range on the gimbals is variable. You can adjust the transmit power by setting up profiles on the gimbal website(the default profile is some gimbal specific thing, but you can also apply profiles to act as a pure Bluetooth beacon)
In my tests with the tx power, i was able to keep the range from about a foot at lowest tx power, and 20-ish feet in an apartment with the fuller tx power settings. So with some trial and error for your space I think you can dial in that setting to keep signals contained within rooms.
Personally not used this solution myself, I have all the parts just not got round to it. If you look at part 9 of these instructions he goes over tracking his dog but this could be applied to humans etc. Plus lots of other sensors you could potentially make with long battery life: https://www.hackster.io/erictsai/lora-tooth-small-ble-sensors-over-wifi-lora-gateways-0aa109
I bought a few of these but I can’t get my head around setting one up to advertise its UUID. Only the Gimbal Manager app will detect it which is of little use as I’d like to trigger an automation when the beacon is detected by the phone. Could you share how you implemented yours within hassio?
Solved it, in case anybody is trying to do the same thing here’s the instructions on how to set up a $5 Gimbal beacon as an iBeacon:
You can then set up a zone within hassio to determine whether you’re within the range of the beacon and trigger automations with it (in my case open the garage door).
