Cheap PAR16 / Short E27 Spotlight bulb
I’m looking for a cheap (preferably <14 USD) E27 spotlight light bulb. I’d like it to have RGB, but white-only with changing color temp would still be fine. Something similar to the Phillips hue PAR16 would be great. Does a bulb like this exist?
EDIT: Wi-Fi or universal zigbee would be preferable
EDIT 2: I currently have compact fluorescent bulbs in all 10 light fittings.
I have an RGB one that is controlled by an IR remote control. You can use it with something like a Broadlink RM blaster to control it with HA. Yeah, not elegant but it works, and its very cheap.
Could you please send a link?
look for Jiawen, is hue compatible and is around 15. On gearbest
Ok, thanks. Does that mean it will pair with the hue bridge?
yes, but I made a mistake, is simple E27, not spotlight
Oh, ok. Do you know any similar E27 spotlight bulbs?
don’t expect perfection…its just a really cheap remote controlled RGB bulb. Since its IR, it can be controlled by Broadlink, hence HA.
https://www.ebay.com/itm/RGB-Magic-Spot-Light-Bulb-E27-3W-RGB-LED-Lamp-with-Wireless-Remote-Controller/162793134286?hash=item25e73a18ce:m:m5r155hdGUkMy_pVIaEsQ9A
