which is the cheapest Socket Switch (EU) which is supported by HA?
Thanks in advance.
Thanks in advance.
Please clarify ‘socket switch’
Are you referring to a smart plug?
or a in wall switch that is constantly on, so you can use a software switch to turn on/off lights for example
Or something else??
I suggest you try vesternet.com - they have both of the above
Edit:
Probably the TP-Link HS100/110’s.
If your after half a dozen or so, cheap RF ones and an RM Pro to control them works well. Only downside is no feedback from the socket to confirm state but I don’t have any issue with the ones I use
