Cheap Yellow ESP32 Display as a garage door button and status display
It took me a few days to get this project to this point. I think I can now call it “finished” but who knows. I benefited greatly from searching threads when trying to figure out how to write the config, but there doesn’t seem to be a lot of content pertaining to these cheap yellow displays. I would like to post my yaml so others might benefit from my work.
The cheap yellow display does the following:
  • Shows a blue “closed” garage door mdi icon when the garage is closed, with the word CLOSED at the bottom of the screen
  • Shows a yellow “open” garage door mdi icon when the garage is open, with the word OPEN at the bottom of the screen
  • Shows a yellow mdi icon of a person inside the garage when there is motion detected inside the open garage, and a black icon when the garage is closed (because the door of the closed garage icon is blue)
  • Shows a red “open” garage door mdi icon when the garage is open AND there has been no motion detected inside the garage for ten minutes, with the amount of time the open garage has been unoccupied (“stagnant”) displayed at the bottom of the screen (10 Minutes, 11 Minutes, etc.)
  • Triggers the garage door button when the screen is touched for 500ms and slowly flashes the rear blue LED one time
  • Shows not only the states OPEN and CLOSED, but also OPENING and CLOSING, based on the amount of time the door travels
I’m not an expert, so feel free to offer any advice. The display is working as I’d planned, so I am not seeking any advice, though.
captive_portal:
spi:
  - id: tft
    clk_pin: GPIO14
    mosi_pin: GPIO13
    miso_pin: GPIO12
  - id: touch
    clk_pin: GPIO25
    mosi_pin: GPIO32
    miso_pin: GPIO39
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_blue
    red: 33%
    green: 47%
    blue: 61%
  - id: my_yellow
    red: 95%
    green: 97%
    blue: 8%
  - id: my_black
    red: 0%
    green: 0%
    blue: 0%
image:
  - file: mdi:garage
    resize: 220x220
  - file: mdi:garage-open
    resize: 220x220
  - file: mdi:walk
    resize: 50x50
number:
    optimistic: true
    min_value: 9
    max_value: 1430
    step: 1
    internal: false
script:
  - id: timer
    mode: restart
    then:
      - number.increment: timer_garage_is_unoccupied
      - delay: 1min
      - script.execute: timer
binary_sensor:
  - platform: homeassistant
    name: "Garage Door Open"
    entity_id: binary_sensor.garage_door_sensor ### My door open/closed sensor
    internal: true
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_off: garage_door_open
          then:
            - binary_sensor.template.publish:
                state: off
                state: off
          else:
            - delay: 10min
            - if:
                condition:
                  for:
                    time: 10min
                    condition:
                      binary_sensor.is_on: garage_door_open
                then:
                      state: on
    entity_id: binary_sensor.motion_inside_garage
    internal: true
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_on: garage_motion
          then:
                state: off
                state: off
          else:
            - delay: 10min
            - if:
                condition:
                  for:
                    time: 10min
                    condition:
                      binary_sensor.is_off: garage_motion
                then:
                      state: on
                else:
                      state: off
    name: "Garage Door Button"
    name: "Garage Motion Is Stagnant"
    internal: false
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_on: garage_motion_is_stagnant
          then:
          else:
            - script.stop: timer
            - number.set:
                value: 9
    name: "Garage Door Open For 10 Minutes"
    internal: true
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_on: no_motion_for_10_minutes
          then:
                state: on
    name: "No Motion For 10 Minutes"
    internal: true
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_on: garage_door_open_for_10_minutes
          then:
                state: on
    internal: False
    lambda: |-
      auto touch = id(my_touchscreen)->get_touch();
      if (id(touch).state > 0) {
      return true;
      } else {
      return false;
text_sensor:
    entity_id: sensor.garage_door_esp32_garage_door_opening_open_closing_closed
    internal: true
button:
    name: Garage Door Touchscreen ESP32 Button
    internal: true
    on_press:
      then:
        - lambda: |-
            id(garage_door_button_binary_sensor).publish_state(true);
        - delay: 0.5s
        - lambda: |-
            id(garage_door_button_binary_sensor).publish_state(false);
font:
  - file: "https://github.com/pjobson/Microsoft-365-Fonts/raw/main/S/Segoe%20UI%20Black.ttf"
display:
  - platform: ili9xxx
    model: tft 2.4
    spi_id: tft
    cs_pin: GPIO15
    dc_pin: GPIO2
    rotation: 90
    lambda: |-
      if (id(garage_door_open).state) {{{
      if (id(garage_motion_is_stagnant).state) {{
      it.image(50, 0, id(garage_open), id(my_red));
      it.printf(160, 210, (segoe_ui_black_font), my_red, TextAlign::CENTER, "%.0f Minutes", id(timer_garage_is_unoccupied).state);
      }} else {{
      it.image(50, 0, id(garage_open), id(my_yellow));
      it.print(160, 210, (segoe_ui_black_font), my_yellow, TextAlign::CENTER, id(garage_door_status).state.c_str());
      if (id(garage_motion).state) {
      it.image(140, 140, id(person), id(my_yellow));
      } else {
      }}} else {{{
      it.image(50, 0, id(garage), id(my_blue));
      it.print(160, 210, (segoe_ui_black_font), my_blue, TextAlign::CENTER, "CLOSED");
      it.image(140, 140, id(person), id(my_black));
      } else {
touchscreen:
  - platform: xpt2046
    display: cyd
    spi_id: touch
    cs_pin: GPIO33
    interrupt_pin: GPIO36
    update_interval: 50ms
    transform:
      mirror_x: false
      mirror_y: false
      swap_xy: false
    calibration:
      x_max: 320
      y_max: 240
    on_touch:
      then:
        - light.turn_on:
            brightness: 100%
        - delay: 0.5s
        - if:
            condition:
              - binary_sensor.is_on: screen_touch
            then:
              - light.turn_on:
                  red: 0%
                  green: 75%
                  blue: 100%
              - button.press: garage_door_touchscreen_esp32_button
              - delay: 1.5s
              - light.dim_relative:
                  relative_brightness: -100%
                  transition_length: 1s
    on_release:
      then:
        - light.turn_on:
            brightness: 75%
output:
  - platform: ledc
    pin: GPIO21
  - platform: ledc
    pin: GPIO4
    inverted: true
  - platform: ledc
    pin: GPIO16
    inverted: true
  - platform: ledc
    pin: GPIO17
    inverted: true
light:
  - platform: monochromatic
    output: backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
    internal: True
    on_turn_on:
      then:
        - light.turn_on:
            brightness: 75%
            red: 100%
            green: 100%
            blue: 1.0
  - platform: rgb
    restore_mode: ALWAYS_OFF
    red: led_red
    green: led_green
    blue: led_blue
    internal: True
Edit:
Here is the yaml for the Open, Opening, Closing, Closed sensor, taken from the ESP32 that controls the relays for the garage door opener inside the garage. There might be an easier way to do this with lambda, but I’m not a lambda expert.
binary_sensor:
    name: "Garage Door Sensor"
    internal: true
    name: "Garage Door Malfunction"
    ### When this is On HA will notify me that the door has malfunctioned
button:
    name: Garage Door Button
    icon: "mdi:garage"
    on_press:
     then:
      - switch.turn_on: garage_door_button_switch
      - if:
          condition:
            - binary_sensor.is_off: garage_door_sensor
          then:
            - text_sensor.template.publish:
                state: OPENING
            - delay: 9s
            - if:
                condition:
                  - binary_sensor.is_on: garage_door_sensor
                then:
                      state: OPEN
                else:
                      state: CLOSED
                  - delay: 9s
                  - if:
                      condition:
                      then:
                            state: OPEN
                      else:
                            state: CLOSED
                            state: On
                        - delay: 60s
                            state: Off
          else:
                state: CLOSING
            - wait_until:
                condition:
                timeout: 11s
            - if:
                condition:
                then:
                      state: CLOSED
                else:
                      state: OPEN
                      state: On
                  - delay: 60s
                      state: Off
We want piccies.
You’ve been a big help to me and many others, Nick. When you ask me for photos, you get photos.
But they’re not great photos. Actually, they’re mostly screenshots from iPhone video. I’m not a big fan of YT so I don’t post videos much. Here is the open/close process. Notice the blue LED that lights up from the back of the unit when the screen is touched for 500ms (thus, triggering the button).
And here is motion in the open garage, and then no motion for 12 minutes (red indicator starts at 10 minutes and increases at one-minute interval).
Cool. You wouldn’t call that ui too crowded. Great for old eyes.
Hi @toreupfeet ,
this looks great.
I have been looking for such an example for a while.
Could you please include the esp32 section. showing what board, framework, platform and other options you are using?
preferably include the whole yaml file.
Thanks,
Ghassan
When I posted the original yaml, I had tidied up some of the entity names in order to make it easy to follow.
Here is the full yaml with no such revisions.
esphome:
  friendly_name: Garage Door Touchscreen ESP32
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ### Yours will be different
ota:
  password: ### Yours will be different
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: ### Yours will be different
captive_portal:
spi:
  - id: tft
    clk_pin: GPIO14
    mosi_pin: GPIO13
    miso_pin: GPIO12
  - id: touch
    clk_pin: GPIO25
    mosi_pin: GPIO32
    miso_pin: GPIO39
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_blue
    red: 33%
    green: 47%
    blue: 61%
  - id: my_green
    red: 15%
    green: 100%
    blue: 15%
  - id: my_yellow
    red: 95%
    green: 97%
    blue: 8%
  - id: my_black
    red: 0%
    green: 0%
    blue: 0%
image:
  - file: mdi:garage
    resize: 220x220
    resize: 220x220
  - file: mdi:walk
    resize: 50x50
#  - file: mdi:garage-lock
#    id: garage_lock
#    resize: 220x220
number:
    optimistic: true
    min_value: 9
    max_value: 1430
    step: 1
    internal: false
script:
  - id: timer
    mode: restart
    then:
      - number.increment: timer_garage_unoccupied
      - delay: 1min
binary_sensor:
    name: "Garage Door Open Closed"
    entity_id: binary_sensor.garage_door_sensor_window_door_is_open
    internal: true
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_off: garage_door_open_closed
          then:
                state: off
                state: off
          else:
            - delay: 10min
            - if:
                condition:
                  for:
                    time: 10min
                    condition:
                      binary_sensor.is_on: garage_door_open_closed
                then:
                      state: on
    internal: true
    on_state:
      then:
        if:
          condition:
          then:
                state: off
                state: off
          else:
            - delay: 10min
            - if:
                condition:
                  for:
                    time: 10min
                    condition:
                then:
                      state: on
                else:
                      state: off
    entity_id: switch.garage_door_esp32_garage_door_lock
    internal: true
    name: "Garage Motion Stagnant"
    internal: false
    on_state:
      then:
        if:
          condition:
            binary_sensor.is_on: garage_motion_stagnant
          then:
          else:
            - number.set:
                value: 9
    internal: true
    on_state:
      then:
        if:
          condition:
          then:
                state: on
    internal: true
    on_state:
      then:
        if:
          condition:
          then:
                state: on
    internal: False
    lambda: |-
      return true;
      } else {
      return false;
text_sensor:
    internal: true
button:
    internal: true
    on_press:
      then:
        - lambda: |-
        - delay: 0.5s
        - lambda: |-
font:
display:
  - platform: ili9xxx
    model: tft 2.4
    spi_id: tft
    cs_pin: GPIO15
    dc_pin: GPIO2
    rotation: 90
    lambda: |-
      if (id(garage_door_open_closed).state) {{{
      if (id(garage_motion_stagnant).state) {{
      it.printf(160, 210, (segoe_ui_black_font), my_red, TextAlign::CENTER, "%.0f Minutes", id(timer_garage_unoccupied).state);
      }} else {{
      } else {
      }}} else {{{
      } else {
touchscreen:
  - platform: xpt2046
    display: cyd
    spi_id: touch
    cs_pin: GPIO33
    transform:
      mirror_x: false
      mirror_y: false
      swap_xy: false
    calibration:
      x_max: 320
      y_max: 240
    on_touch:
      then:
        - light.turn_on:
            brightness: 100%
        - delay: 0.5s
        - if:
            condition:
            then:
              - light.turn_on:
                  red: 0%
                  green: 75%
                  blue: 100%
              - if:
                  condition:
                    - binary_sensor.is_on: garage_motion_stagnant
                  then:
                        state: off
              - delay: 1.5s
    on_release:
      then:
        - light.turn_on:
            brightness: 75%
output:
  - platform: ledc
    pin: GPIO21
  - platform: ledc
    pin: GPIO4
    inverted: true
  - platform: ledc
    pin: GPIO16
    inverted: true
  - platform: ledc
    pin: GPIO17
    inverted: true
light:
    internal: True
    on_turn_on:
      then:
        - light.turn_on:
            brightness: 75%
            red: 100%
            green: 100%
            blue: 1.0
  - platform: rgb
    red: led_red
    green: led_green
    blue: led_blue
    internal: True
thanks a lot,
Now I have a working simplified “Hello world” example.
My intention is to try to use lvgl which I expect will be easier to mange the graphics.
I found othert examples doing that but either using arduino with this display, or using esphoime with another display,
i hope i can ,manage to get it working with this dsplay in esphome.
Kind regards,
Ghassan.
ESPHome seems to have made some breaking changes and I’ve had to modify my yaml to keep my device working. Here is my latest config. Oh, and my touchscreen was experiencing ghost touches, which caused my garage door button to be pressed inadvertently, so I disabled the touchscreen feature. I just use a Zigbee button now.
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
    key: "XXXX"
ota:
  password: "XXXX"
  platform: esphome
wifi:
  ap:
    ssid: "Garage-Door-Touchscreen-Esp32"
    password: "XXXX"
captive_portal:
spi:
  - id: tft
    clk_pin: GPIO14
    mosi_pin: GPIO13
    miso_pin: GPIO12
  - id: touch
    clk_pin: GPIO25
    mosi_pin: GPIO32
    miso_pin: GPIO39
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_blue
    red: 33%
    green: 47%
    blue: 61%
  - id: my_green
    red: 15%
    green: 100%
    blue: 15%
  - id: my_yellow
    red: 95%
    green: 97%
    blue: 8%
  - id: my_black
    red: 0%
    green: 0%
    blue: 0%
image:
  - file: mdi:garage
    resize: 220x220
    type: BINARY
    resize: 220x220
    type: BINARY
  - file: mdi:walk
    resize: 50x50
    type: BINARY
#    id: garage_lock
#    resize: 220x220
number:
    optimistic: true
    min_value: 9
    max_value: 1430
    step: 1
    internal: false
script:
  - id: timer
    mode: restart
    then:
      - delay: 1min
binary_sensor:
    internal: true
    on_state:
      then:
        if:
          condition:
          then:
                state: off
                state: off
          else:
            - delay: 10min
            - if:
                condition:
                  for:
                    time: 10min
                    condition:
                then:
                      state: on
    internal: true
    on_state:
      then:
        if:
          condition:
          then:
                state: off
                state: off
          else:
            - delay: 10min
            - if:
                condition:
                  for:
                    time: 10min
                    condition:
                then:
                      state: on
                else:
                      state: off
    internal: true
    internal: false
    on_state:
      then:
        if:
          condition:
          then:
          else:
            - number.set:
                value: 9
    internal: true
    on_state:
      then:
        if:
          condition:
          then:
                state: on
    internal: true
    on_state:
      then:
        if:
          condition:
          then:
                state: on
    internal: False
    lambda: |-
      // return true;
      return false;
      } else {
      return false;
text_sensor:
    internal: true
#  - platform: template
#    name: "Timer Number Text Sensor"
#    id: timer_number_text_sensor
#    update_interval: 10s
#    internal: true
button:
    internal: true
    on_press:
      then:
        - lambda: |-
        - delay: 0.5s
        - lambda: |-
font:
display:
  - platform: ili9xxx
    model: tft 2.4
    color_palette: 8BIT
    spi_id: tft
    cs_pin: GPIO15
    dc_pin: GPIO2
    rotation: 90
    invert_colors: false
    lambda: |-
      }} else {{
      } else {
      }}} else {{{
      } else {
#      it.print(160, 210, (segoe_ui_black_font), my_red, TextAlign::CENTER, id(timer_number_text_sensor).state.c_str());
touchscreen:
  - platform: xpt2046
    display: cyd
    spi_id: touch
    cs_pin: GPIO33
    transform:
      mirror_x: false
      mirror_y: false
      swap_xy: false
    calibration:
      x_max: 320
      y_max: 240
      x_min: 0
      y_min: 0
    on_touch:
      then:
        - light.turn_on:
            brightness: 100%
#        - light.turn_on:
#            id: garage_door_touchscreen_esp32_rear_led
#            red: 0%
#            green: 0%
#            blue: 100%
        - delay: 0.5s
        - if:
            condition:
            then:
              - light.turn_on:
                  red: 0%
                  green: 75%
                  blue: 100%
              - if:
                  condition:
                  then:
                        state: off
              - delay: 1.5s
    on_release:
      then:
        - light.turn_on:
            brightness: 75%
output:
  - platform: ledc
    pin: GPIO21
  - platform: ledc
    pin: GPIO4
    inverted: true
  - platform: ledc
    pin: GPIO16
    inverted: true
  - platform: ledc
    pin: GPIO17
    inverted: true
light:
    internal: True
    on_turn_on:
      then:
        - light.turn_on:
            brightness: 75%
            red: 100%
            green: 100%
            blue: 1.0
  - platform: rgb
    red: led_red
    green: led_green
    blue: led_blue
    internal: True
