Good day, i have finally jumped the gap and installed home assistant, for that reason i have started testing with this 6 button switch TuYa TS0046 control via MQTT | Zigbee2MQTT
And this zigbee adaptor
After testing, i see in logs of Zigbee2MQTT the corresponding actions, and buttons clicking, but sometimes they are missing for 5 seconds or so.
For example i press buttons 1 2 3 4 5 6 1 2 3 4 5 6 and in the middle i dont get 1 2
I have tried to test with different button swiches i have, and looks like it is the same.
Do you think its because of a cheap adaptor our because my setup is a VM with usb passthrough ? I am testing near the server so it is not a distance problem.
Should i buy a network Zigbee gateway instead ?
Thank you
Greg
