Check Battery Level using Node Red
I am new in-home automation especially using Node-Red. I have about 5 Zigbee door sensors that I would like to set up notification using Node-Red so if the battery level drops to 10% I will get ios notification including what door and what is the current battery level. Below is my current code. it works but I can’t get to show what door the notification is coming from. If you guys have another approach I am willing to give a try.
        "id": "6f352f41.b3a56",
        "type": "switch",
        "z": "2bcdf7f.373dc08",
        "name": "Check Battery",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "lt",
                "v": "92",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 860,
        "y": 220,
        "wires": [
                "d49efa1d.d6d868"
        "id": "b57e03e3.e9fa2",
        "type": "api-call-service",
        "name": "Notify Garen",
        "server": "5264684c.884f58",
        "version": 1,
        "debugenabled": false,
        "service_domain": "notify",
        "service": "ios_garens_iphone",
        "entityId": "",
        "data": "{}",
        "dataType": "json",
        "mergecontext": "",
        "output_location": "payload",
        "output_location_type": "msg",
        "mustacheAltTags": false,
        "x": 1250,
        "y": 220,
        "wires": [
        "id": "d49efa1d.d6d868",
        "type": "function",
        "name": "Data",
        "func": "msg.payload = \n{\n  \"data\": \n  {\n    \"message\": msg.payload\n  }\n}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1070,
        "y": 220,
        "wires": [
                "b57e03e3.e9fa2"
        "id": "60a602a5.6256cc",
        "type": "inject",
        "name": "",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 100,
        "y": 220,
        "wires": [
                "5d93d9d1.b743c8"
        "id": "5d93d9d1.b743c8",
        "type": "api-current-state",
        "name": "",
        "version": 1,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "override_topic": false,
        "entity_id": "sensor.garage_back_door_sensor_battery_level",
        "state_type": "str",
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "blockInputOverrides": false,
        "x": 450,
        "y": 220,
        "wires": [
                "6f352f41.b3a56"
        "id": "5264684c.884f58",
        "type": "server",
        "z": "",
        "name": "Home Assistant",
        "legacy": false,
        "hassio": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": false,
        "cacheJson": true
[{"id":"db53cd47.aa026","type":"api-call-service","z":"441512b6.56dcdc","name":"Notify Garen","version":1,"debugenabled":false,"service_domain":"notify","service":"ios_garens_iphone","entityId":"","data":"{\"message\":\"{{data.attributes.friendly_name}} battery is at {{payload}} percent.\"}","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":838,"y":128,"wires":[[]]},{"id":"3e19385d.8d9958","type":"inject","z":"441512b6.56dcdc","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":136,"y":128,"wires":[["9906aed8.c889e"]]},{"id":"9906aed8.c889e","type":"api-current-state","z":"441512b6.56dcdc","name":"","version":1,"outputs":2,"halt_if":"92","halt_if_type":"num","halt_if_compare":"lt","override_topic":false,"entity_id":"sensor.garage_back_door_sensor_battery_level","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":486,"y":128,"wires":[["db53cd47.aa026"],[]]}]
That work perfectly. Thank you
