Check config and if ok restart button
Instead of first pressing the check config button before reboot - it would be nice if this would be done by default or by a third button - if everything is fine ha restart, otherwise gives a warning.
It already does that. The restart button will also check your configuration. If it finds an error it will tell you that and abort the restart.
ā€¦/Frenck
