The “Check Config” button should check entity_ids to see if they actually exist, and give a warning and reference to a file and line number if they do not exist.
As of 0.70.0 this does not happen.
Current behavior:
In entity_registry.yaml I called something “switch.front_porch” but in automations.yaml I entered “switch.front_patio”. Check Config happily validates the YAML, but does not tell me “switch.front_patio” does not exist. I only find out later in the logs when I get “reproduce_state: Unable to find entity switch.front_patio”. Since some automations are called infrequently, this may not be apparent for some time.
Desired behavior:
Check Config validates the YAML, then proceeds to validate entity_ids on all !included yaml files. It generates a warning such as “Warning: unknown entity_id ‘switch.front_patio’ in automations.yaml on line 72.”
I can help code and test such a feature if pointed in the right direction.
