Hello all,
I’m hoping you can help me deep dive into fixing this issue. I really don’t want to have to start over with my home assistant instance.
This issue has existed ever since version 22.06 on my machine. I can get every component in the list within developer tools to reload successfully. When I comment out my old yaml mqtt code (below) that (validates in the configurator) and then uncomment the new version after clicking the “Check configuration” button on this screen, the blue thing just spins forever and never completes. If I put the code back to the old mqtt format. The configuration check completes successfully.
I’ll be honest, this is the 3rd time I have posted this issue here in hopes that someone new will come along and spot the issue or possibly direct me to someone in development that can look into this further.
Thank you all for all of the help you have given me in the past and I’m hoping someone can help me solve this.
I have my mqtt config stored in a package and called into my main config. Below is a copy paste of the file, the area called “NEW” is what causes the check config to never complete, if I comment that area out and uncomment the area called “OLD”, the check config completes.
Hopefully you all can help direct this to the proper channel if no one can figure this out.
Thank you all again, I am at a complete loss on this one.
input_boolean:
washer_finished:
icon: mdi:washing-machine
input_number:
stepper_control_right_test_blind:
name: Stepper Control Right Test Blind
min: -200
max: 460
step: 1
mode: slider
stepper_control_left_test_blind:
name: Stepper Control Left Test Blind
min: -200
max: 700
step: 1
mode: slider
#####NEW######
mqtt:
- name: "Washer Status"
state_topic: "house/washer/status"
- name: "Washer Last Complete"
state_topic: "house/washer/time_complete"
device_class: timestamp
- name: "Washer Last Emptied"
state_topic: "house/washer/time_emptied"
#####/NEW######
#####/OLD######
# - platform: "mqtt"
# name: "Washer Status"
# state_topic: "house/washer/status"
# name: "Washer Last Complete"
# state_topic: "house/washer/time_complete"
# device_class: timestamp
# name: "Washer Last Emptied"
# state_topic: "house/washer/time_emptied"
# One entry for each beacon you want to track
- platform: mqtt_room
device_id: "apple:1006:10-8"
name: 'Westons iPhone Room Presence'
state_topic: 'espresense/devices/apple:1006:10-8'
timeout: 10
away_timeout: 120
#####/OLD######
####NOT USING CURRENTLY####
# # MQTT Sensor for DishWasher Status.
# - platform: mqtt
# name: "DishWasher Status"
# state_topic: "house/dishwasher/status"
# MQTT Sensor for Washing Machine Status.
# - platform: mqtt_room
# device_id: 123testid
# state_topic: "espresense/rooms"
####/NOT USING CURRENTLY####
utility_meter:
washer_daily_kwh:
source: sensor.washer_switch_electric_consumed_kwh
cycle: daily
washer_weekly_kwh:
cycle: weekly
automation:
- id: washer_running
alias: Washer Running
- above: 4
entity_id: sensor.washer_power_consumed_w
platform: numeric_state
condition:
condition: or
conditions:
- condition: state
entity_id: sensor.washer_status
state: idle
- condition: state
state: complete
- service: mqtt.publish
topic: house/washer/status
payload: running
retain: true
initial_state: true
- id: washer_complete
alias: Washer Complete
- below: 2
condition:
- condition: state
state: running
payload: complete
retain: true
topic: house/washer/time_complete
payload: "{{ utcnow().isoformat() }}"
# payload: '{{ now().timestamp() }}'
retain: true
initial_state: true
- id: washer_notification
initial_state: true
alias: Washer Notification
- platform: state
to: complete
- service: script.speech_engine
# who: 'kitchen'
message: "Just a quick heads up, It appears the washing machine has completed its cycle"
- service: script.text_notify
who: parents
title: Washing Machine Finished
group: "appliances"
tag:
- service: script.turn_on
entity_id: script.washer_finished_notification_audible
data: {}
entity_id: input_boolean.washer_finished
- id: washer_emptied
initial_state: true
alias: Washer Emptied
- platform: state
entity_id: binary_sensor.washer_door
to: "on"
payload: idle
retain: true
- service: script.turn_off
topic: house/washer/time_emptied
retain: true
- service: input_boolean.turn_off
data: {}
script:
washer_finished_notification_audible:
sequence:
- repeat:
while:
- condition: state
state: "complete"
sequence:
- delay:
minutes: 30
- service: script.simplified_washer_audible
simplified_washer_audible:
sequence:
- condition: state
entity_id: group.family
state: "home"
- condition: state
state: complete
# who: 'kitchen'
message: >
'Pardon me, ',
'Excuse me, ',
'I do not mean to interrupt, but,',
'I hate to interrupt, but,',
'I beg your pardon, ',
'I do not mean to intrude, but, ',
'I am sorry to interrupt, but. ',
'Just a quick heads up, '
] | random }}
<p>
The washing machine completed its cycle
{% set seconds = now().timestamp() - as_timestamp(states.sensor.washer_status.last_changed) %}
{% if (seconds / ( 60 * 60 )) | int == 1 %}
over an hour ago.
'Do not forget to rotate the clothes.',
'Was someone going to rotate the laundry?',
'Once you rotate the laundry I will stop reminding you to do it. So if you want me to stop. Its up to you.'
] | random }}
{% elif (seconds / ( 60 * 60 )) | int > 1 and (seconds / ( 60 * 60 )) | int < 6 %}
over {{ (seconds // ( 60 * 60 )) | int }} hours ago.
'Much longer and you are going to need to wash them again.',
'Someone needs to rotate the laundry.',
'Do not forget about the clothes in the washing machine.',
'Surely you did not mean to forget about the clothes. Mistakes happen. But you can still fix it.',
'Do you like your clothes smelling like mildew? Becasue that is what is happening right now.'
] | random }}
{% elif (seconds / ( 60 * 60 )) | int > 6 %}
'That is a crazy amount of time.',
'Did you decide you want those clothes to suffer?',
'You might as well just rewash those clothes.',
'I can smell the mildew. Virtually that is.',
'Surely you did not mean to forget about the clothes.'
] | random }}
{% else %}
{{ (seconds // 60) | int }} minutes ago.
'Someone forgot to move the clothes to the dryer. I am not going to name names, but there is a camera in there. Do I need to publically shame someone?',
'You might want to move them to the dryer.'
] | random }}
{% endif %}
</p>
washer_idle:
sequence:
payload: idle
retain: true
washer_running:
sequence:
payload: running
retain: true
washer_complete:
sequence:
payload: complete
retain: true
retain: true
#################REMNANTS- AUTOMATIONS
# - id: e1cb26fe-0423-11eb-adc1-0242ac120002
# initial_state: true
# alias: Dryer Notification
# trigger:
# - platform: state
# entity_id: binary_sensor.dryer_dry_completed
# from: 'off'
# to: 'on'
# action:
# - service: script.status_annc
# data:
# who: '{{ states.sensor.room_presence.state }}'
# call_interruption: 1
# speech_message: It appears the dryer has finished.
# - delay:
# minutes: 15
# # - service: script.turn_on
# # entity_id: script.dryer_finished_notification_audible
# - id: dishwasher_idle
# alias: Dishwasher Idle
# trigger:
# - platform: state
# entity_id: device_tracker.dishwasher
# to: 'not_home'
# action:
# - service: script.dishwasher_idle
# # When dishwasher connects to network assume it is running cycle.
# - id: dishwasher_running
# alias: Dishwasher Running
# trigger:
# - platform: state
# to: 'home'
# action:
# - service: script.dishwasher_running
#################REMNANTS- SCRIPTS
# dryer_finished_notification_audible:
# sequence:
# - repeat:
# while:
# - condition: state
# entity_id: sensor.washer_status
# state: 'complete'
# sequence:
# - service: script.dryer_audible
# - delay:
# minutes: 45
# dishwasher_idle:
# sequence:
# - service: mqtt.publish
# data:
# topic: house/dishwasher/status
# payload: idle
# retain: true
# dishwasher_running:
# sequence:
# data:
# payload: running
# retain: true
