Check configuration & restart not working
after updating to 2022.7, the check configuration does not work (continues spinning for hours); also the restart does not work (nothing happens)
any idea what might be wrong and how to fix it
… and after updating to 2022.7.1 i lost all automation (the automation.yaml is there but the automations do not work and do not show up in the ui)?
Check your logs.
Same issue here I think
I had the same issue, Chek configuration spinning for a long time until it actually finished and spit out errors in the config file. After fixing those, like the new changes for the mqtt binary_sensor and disabling broken Tapo plugs integration, the check and restart worked just fine.
