hello guys! Can you tell me how to check from home assistant when a device connected via MQTT is on or off? I tried with the Nmap Tracker integration and it worked quite well, but I would like to know if there is a better alternative method. Thanks in advance
use mqttexplorer to see if device publishes if its on/off
You could subscribe to such topics then with a binary sensor to say if on/off
LWT = last will and testament
