Check for state of the AC as trigger
Best practice, do you think that there is a need to check the AC state as an automation trigger?
What I have today is:
  - platform: numeric_state
    entity_id:
      - zone.home
    above: 0
    value_template: "{{is_state('climate.midea_ac_1', 'off')}}"
  - platform: time
    at: "08:00:00"
    enabled: true
    entity_id:
      - sensor.living_room_thermostat_temperature
    above: 80
    enabled: true
or should I just keep this as trigger
    entity_id:
      - zone.home
    above: 0
  - platform: time
    at: "08:00:00"
    enabled: true
    entity_id:
    above: 22
    enabled: true
and check ‘state’ as a condition
condition: template
Thank you
those are usually two very different things… so it depends on what you want.
add to the trigger if you want your actions to be run when the AC turns off
Add to conditions if you want the actions to run when the other triggers happen and the AC is already off.
It’s not about best practice. It’s about what behavior you want
@armedad
Thanks, I was thinking of the two ways but was unsure (newbie)… In my case it would be the latter.
well… welcome… if you’re a newbie and want a jump start i’d really recommend you look at some of the stuff here… don’t be daunted by the quantity. scan the titles then skim the ones under automation. a little bit of time on that will save you hours and hours later:
