Hello community,
recently I migrated my setup from a RPi to a NUC following the generic linux tutorial with Ubuntu Server 18.04 LTS.
At the moment I’m running HA 91.4 which I also used for the setup on the NUC.
I tried to check the configuration agaionst HA 92.0 but the addons fails with these log entries:
[Info] Start install HomeAssistant latest
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f51e304e940>: Failed to establish a new connection: [Errno -3] Try again')': /simple/homeassistant/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f51e304ea58>: Failed to establish a new connection: [Errno -3] Try again')': /simple/homeassistant/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f51e30429e8>: Failed to establish a new connection: [Errno -3] Try again')': /simple/homeassistant/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f51e3042fd0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/homeassistant/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f51e3042748>: Failed to establish a new connection: [Errno -3] Try again')': /simple/homeassistant/
Could not find a version that satisfies the requirement homeassistant (from versions: )
No matching distribution found for homeassistant
[Error] Install HomeAssistant: Collecting homeassistant
I suspect it is realted to either Ubuntu or Docker but I’m quite quite new to both worlds.
Hope that someone can point me into the right direction.
