"Check Home Assistant configuration" error help with 2022.8.1 install
Hello all -
I’ve spent a lot of time on the forum trying to find information on how to fix this, but unfortunately, I couldn’t. I’m trying to install 2022.8.1, but I get a long error message with the “Check Home Assistant configuration” add-on.
I run Home Assistant Blue/ODROID-N2.
I would appreciate any help with this.
Here is the error:
Downloading aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
Collecting pytz
  Downloading pytz-2022.1-py2.py3-none-any.whl (503 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 503.5/503.5 KB 12.0 MB/s eta 0:00:00
Collecting six>=1.4.1
  Downloading six-1.16.0-py2.py3-none-any.whl (11 kB)
Collecting cffi>=1.1
  Downloading https://wheels.home-assistant.io/alpine-3.14/aarch64/cffi-1.15.1-cp39-none-any.whl (189 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 189.2/189.2 KB 3.7 MB/s eta 0:00:00
Collecting bleak>=0.14.3
  Downloading bleak-0.15.1-py2.py3-none-any.whl (123 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 124.0/124.0 KB 10.5 MB/s eta 0:00:00
Collecting httpcore<0.16.0,>=0.15.0
  Downloading httpcore-0.15.0-py3-none-any.whl (68 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 68.4/68.4 KB 6.7 MB/s eta 0:00:00
Collecting rfc3986[idna2008]<2,>=1.3
  Downloading rfc3986-1.5.0-py2.py3-none-any.whl (31 kB)
Collecting sniffio
  Downloading sniffio-1.2.0-py3-none-any.whl (10 kB)
Collecting MarkupSafe>=2.0
  Downloading MarkupSafe-2.1.1-cp39-cp39-musllinux_1_1_aarch64.whl (30 kB)
Collecting text-unidecode>=1.3
  Downloading text_unidecode-1.3-py2.py3-none-any.whl (78 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 78.2/78.2 KB 7.2 MB/s eta 0:00:00
Collecting urllib3<1.27,>=1.21.1
  Downloading urllib3-1.26.11-py2.py3-none-any.whl (139 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 139.9/139.9 KB 11.9 MB/s eta 0:00:00
Collecting idna<4,>=2.5
  Downloading idna-3.3-py3-none-any.whl (61 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.2/61.2 KB 5.6 MB/s eta 0:00:00
Collecting dbus-next
  Downloading dbus_next-0.2.3-py3-none-any.whl (57 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 57.9/57.9 KB 5.2 MB/s eta 0:00:00
Collecting pycparser
  Downloading pycparser-2.21-py2.py3-none-any.whl (118 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 118.7/118.7 KB 7.9 MB/s eta 0:00:00
Collecting anyio==3.*
  Downloading anyio-3.6.1-py3-none-any.whl (80 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 80.6/80.6 KB 8.1 MB/s eta 0:00:00
Collecting h11<0.13,>=0.11
  Downloading h11-0.12.0-py3-none-any.whl (54 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 54.9/54.9 KB 5.5 MB/s eta 0:00:00
Building wheels for collected packages: lru-dict
  Building wheel for lru-dict (setup.py): started
  Building wheel for lru-dict (setup.py): finished with status 'error'
  error: subprocess-exited-with-error
  × python setup.py bdist_wheel did not run successfully.
  │ exit code: 1
  ╰─> [8 lines of output]
      running bdist_wheel
      running build
      running build_ext
      building 'lru' extension
      creating build
      creating build/temp.linux-aarch64-cpython-39
      gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/local/include/python3.9 -c lru.c -o build/temp.linux-aarch64-cpython-39/lru.o
      error: command 'gcc' failed: No such file or directory
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for lru-dict
  Running setup.py clean for lru-dict
Failed to build lru-dict
Installing collected packages: voluptuous, text-unidecode, rfc3986, pytz, lru-dict, ifaddr, ciso8601, voluptuous-serialize, urllib3, typing-extensions, sniffio, six, pyyaml, python-slugify, PyJWT, pycparser, orjson, multidict, MarkupSafe, idna, h11, frozenlist, dbus-next, charset-normalizer, certifi, awesomeversion, attrs, atomicwrites-homeassistant, async-timeout, astral, yarl, requests, jinja2, cffi, bleak, anyio, aiosignal, httpcore, home-assistant-bluetooth, cryptography, bcrypt, aiohttp, httpx, homeassistant
  Running setup.py install for lru-dict: started
  Running setup.py install for lru-dict: finished with status 'error'
  × Running setup.py install for lru-dict did not run successfully.
  │ exit code: 1
  ╰─> [10 lines of output]
      running install
      /usr/local/lib/python3.9/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
        warnings.warn(
      running build
      running build_ext
      creating build
      [end of output]
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> lru-dict
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
The check_config add-on is deprecated (no longer maintained), so perhaps just delete it?
WARNING: This add-on is deprecated because it is no longer needed. Home Assistant now always starts after an update even if your config is invalid. You should do the following after an update to check for issues:
Hi there - thank you for the reply. If I delete it, how can I check if the install will break anything?
You don’t.
  1. Check persistent notifications. If an integration could not be loaded because its config is invalid a notification will tell you.
  2. Check logs. If an integration could be loaded but the config you are using is deprecated a message will tell you what needs to change and by when.
  3. Follow the red banner. In rare cases HA will start in safe mode. In those cases you should follow the instructions in the red banner at the top of the UI.
And now there are Repairs.
And you read the release notes breaking changes before updating.
Thanks everyone - I’ll give it a try.
