I saw that there was an update so ran my usual Check Home Assistant Configuration Add on and came up with this ERROR which I have no idea what it means so shall no proceed at this stage
Can anyone enlighten me?
Hi!
Can you post the content of your configurations.yaml file where it says âSensrEntityDescriptionâ?
Please redact any sensitive information
I have done a âFindâ for âSensorâ on my configuration.yaml file and cannot find this string???
This is the config of the /usr/share/hassio/share/check_config.txt
rontaylor@nuc-1:/usr/share/hassio/share$ cat check_config.txt
INFO:homeassistant.util.package:Attempting install of colorlog==5.0.1
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of pyhik==0.2.8
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of mutagen==1.45.1
INFO:homeassistant.util.package:Attempting install of gTTS==2.2.3
INFO:homeassistant.util.package:Attempting install of scapy==2.4.5
INFO:homeassistant.util.package:Attempting install of aiodiscover==1.4.2
INFO:homeassistant.util.package:Attempting install of hass-nabucasa==0.44.0
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20210803.2
INFO:homeassistant.util.package:Attempting install of PyNaCl==1.4.0
INFO:homeassistant.util.package:Attempting install of emoji==1.2.0
INFO:homeassistant.util.package:Attempting install of distro==1.5.0
INFO:homeassistant.util.package:Attempting install of defusedxml==0.7.1
INFO:homeassistant.util.package:Attempting install of async-upnp-client==0.19.1
INFO:homeassistant.util.package:Attempting install of zeroconf==0.33.2
INFO:homeassistant.util.package:Attempting install of pillow==8.2.0
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.4.17
INFO:homeassistant.util.package:Attempting install of homeassistant-pyozw==0.1.10
INFO:homeassistant.util.package:Attempting install of python-openzwave-mqtt[mqtt-client]==1.4.0
INFO:homeassistant.util.package:Attempting install of pysensibo==1.0.3
INFO:homeassistant.util.package:Attempting install of aiofiles==0.6.0
INFO:homeassistant.util.package:Attempting install of rflink==0.0.58
INFO:homeassistant.util.package:Attempting install of ephem==3.7.7.0
INFO:homeassistant.util.package:Attempting install of python-forecastio==1.4.0
INFO:homeassistant.util.package:Attempting install of psutil==5.8.0
INFO:homeassistant.util.package:Attempting install of envoy_reader==0.19.0
Fatal error while loading config: '<' not supported between instances of 'SensorEntityDescription' and 'SensorEntityDescription'
Failed config
General Errors:
- '<' not supported between instances of 'SensorEntityDescription' and 'SensorEntityDescription'
Successful config (partial)
This is the entry for my envoy
- platform: enphase_envoy
ip_address: 192.168.0.100
monitored_conditions:
- production
- daily_production
- seven_days_production
- lifetime_production
I hope that is helpful.
I canât pretend to fully understand what that message means but it appears to have a problem with the âless thanâ operatorâs use somewhere in the configuration. Thatâs what i gather from this:
â<â not supported between instances of
Do you have any templates in the configuration that employ the < operator?
I have been through every *.yaml file in the config folder and done a search for â<â and found none.
I loaded 2021.7.4 on 24/7/21 and it had no problem with the config check or the actual load.
The changes I have made since then have been
I keep a log of major chnages and this is what changes were made to my system.
| Date | Time | Action | Outcome |
| 5/08/2021 | 6:20 | Update ESPHome to 1.20.4 | OK |
| 1/08/2021 | 8:50 | Ubuntu Updates | OK |
| 29/07/2021 | 6:45 | Updated Tuya V2 to 1.40.x | OK |
| 26/07/2021 | 14:40 | Updated Tuya V2 to 1.40.2 | OK |
| 25/07/2021 | 1512 | Removed TUYA V1 integration | Installed Tuya V2 HACS in morning and removed V1 in afternoon. |
| 24/07/2021 | Remove Tuya and reinstall with new Tuya app on phone | OK |
I have made some minor changes like renaming a few entities but nothing involving templates.
Beats me.
I also did this
I am assuming that my configuration is correct if this is green and says its valid
Iâm getting the same âsensorentitydescriptionâ error when I try to restart the server.
Some integrations (eg Ecowitt) were not loading despite rebooting the RPi and now HACS is not loading, or at least showing an error. I have just set up the Energy screen so my next step is to delete that.
Update - Snapshot from previous Core version works fine. Something in core-2021.8.1 does not like my current setup. It certainly doesnât like the Ecowitt HACS integration. (Wonât load). I thought it might be a version issue but could not work my way around that.
Perhaps the problem might not be in the configuration but with the loading of an integration. I suggest reporting this as an Issue in the Core repository.
I will try removing the Ecowitt integration before updating
I am not sure how to report this issues in the core repository??
How do I do this?
I tried a RESTART of HA and HA loaded OK.
I agree there is something in the new 2021.8.1 that does not like something.
Get a free GitHub account and then fill in this form:
Thanks.
I have raises an issue. Never done that before.
The issue is Check Home Assistant Configuration fails on 2021.8.1 ¡ Issue #54104 ¡ home-assistant/core ¡ GitHub
New core just uploaded 2021.8.2 fixes the problem for me. It was linked to the HACS Ecowitt (weather station) integration. It was all about the way in which one sensor was described. This might apply to other integrations with sensors.
See reference here:
ping just in case the other one didnât work
I have successfully loaded 2021.8.3.
Steps I took.
This issue took a little while to resolve and thank you to those who had the skills to sort it out.
ECOWITT has proved to be a troublesome HACS integration but itâs very useful to me anyway.
Thanks for raising the issue. The update to fix Enphase appears to have fixed Ecowitt as well.
I just need to make sure I am doing backups before updates - that option is offered - It saved me a lot of grief.
Backups.
I have an automation that does a backup every night at 00:00hrs. This means I donât forget and also saves time with updates.
