I am currently running Hass.io 0.92.2 and want to upgrade to 0.93.1. System is running well right now. Before upgrading, I always use the “Check Home Assistant configuration” plugin to make sure that I don’t get affected by breaking changes (only config paramter is the default one, "version":"latest"). In the past, it’s always been clean.
Today, when I ran it, I get the following in its log:
[Info] Start install HomeAssistant latest
You are using pip version 19.0.3, however version 19.1.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
[Info] Installed homeassistant==0.93.1, check config now
[Error] Wrong config found!
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of mutagen==1.42.0
INFO:homeassistant.util.package:Attempting install of HAP-python==2.5.0
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20190514.0
INFO:homeassistant.util.package:Attempting install of pylutron-caseta==0.5.0
INFO:homeassistant.util.package:Attempting install of influxdb==5.2.0
INFO:homeassistant.util.package:Attempting install of ha-ffmpeg==2.0
INFO:homeassistant.util.package:Attempting install of PyNaCl==1.3.0
ERROR:homeassistant.util.package:Unable to install package PyNaCl==1.3.0: Failed building wheel for PyNaCl
Could not build wheels for PyNaCl which use PEP 517 and cannot be installed directly
ERROR:homeassistant.requirements:Not initializing owntracks because could not install requirement PyNaCl==1.3.0
INFO:homeassistant.util.package:Attempting install of distro==1.4.0
INFO:homeassistant.util.package:Attempting install of netdisco==2.6.0
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.3.3
INFO:homeassistant.util.package:Attempting install of google-api-python-client==1.6.4
INFO:homeassistant.util.package:Attempting install of httplib2==0.10.3
INFO:homeassistant.util.package:Attempting install of oauth2client==4.0.0
INFO:homeassistant.util.package:Attempting install of hass-nabucasa==0.12
INFO:homeassistant.util.package:Attempting install of teslajsonpy==0.0.25
INFO:homeassistant.util.package:Attempting install of twilio==6.19.1
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of ring_doorbell==0.2.3
Failed config
General Errors:
- Unable to install all requirements: PyNaCl==1.3.0
Successful config (partial)
Any idea what could be causing this? If it matters, I am running hass.io in a docker container on Ubuntu 18.04 LTS (which, itself is running as a VM on an ESXi 6.0 server).
Since it is advertised as easing upgrade anxiety & since there is a full-time dev for Hass.io, one would think it would have been tested before the version was deployed.
Perhaps it should be added to the pre-release testing checklist?
Does anyone know if there’s an ETA for when the addon will be working again? Out of paranoia, I’ve been holding off on upgrading from 0.92.2 until I can run the checker.
I keep getting this error and I have uninstall it and reinstall any thoughts
Im running hassio 0.96.5
[11:08:29] INFO: Installing Home Assistant: latest…
[11:08:29] INFO: Please be patient, this might take a few minutes…
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f727abce110>: Failed to establish a new connection: [Errno -3] Try again’)’: /simple/homeassistant/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f727abcef10>: Failed to establish a new connection: [Errno -3] Try again’)’: /simple/homeassistant/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f727ab68090>: Failed to establish a new connection: [Errno -3] Try again’)’: /simple/homeassistant/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f727aba3d90>: Failed to establish a new connection: [Errno -3] Try again’)’: /simple/homeassistant/
