Greetings friends, I am using the “Check Home Assistant configuration” compatibility tool to test the configuration of my system with the new versions of Hass.io.
This tool has reported me in a couple of times that I have used this message:
starting version 3.2.2
[INFO] Start install HomeAssistant 0.72.0
You are using pip version 9.0.1, however version 10.0.1 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
[Info] Install done, check config now
[Info] Finish
Please could you tell me how to do the “pip” update, I tried using putty with the “root” user and the commands accessible without success.
Thank you very much for your help @AlmostSerious, I put the two lines at the end of my file “/config/automations.yaml”, then when reviewing the configuration I get this error message:
Configuration invalid
Invalid config for [automation]: [service] is an invalid option for [automation]. Check: automation-> service. (See /config/configuration.yaml, line 20). Please check the docs at https://home-assistant.io/components/automation/
Thanks @ keithh666, add the “Shell_command” to my configuration.yaml file, restart the system, then I went to the “remote control” of services use the new command with “Call service” and it gives me in the system log this error:
Tue Jun 26 2018 16:47:16 GMT-0600 (hora estándar central)
Error running command: pip install --upgrade pip, return code: 127
NoneType: None
Any suggestions?
Well I have tried investigating how to do the update and I can not do it!
You may be able to check using the supervisor account via ssh, but I wouldn’t bother. If you do it will be something like pip3 -V or -v or --v or --V I can’t remember
