I would like to use a condition to check if motion was detected in the last 5 minutes. This motion sensor is a simple binary sensor with on and off states.
I can use the for 00:05:00 but i think that means motion had to exist without changing states for the last 5 minutes. As i’m not sure how long the motion will exist for, i just want to check if there was any kind of motion in the last 5 minutes. Something that checks if the state changed from on to off in the last 5 minutes.
Hope that makes sense. I might completely misunderstand how it works.
First, check if there is a way to set something like an “occupancy timeout” for your device. I don’t know how you integrated the motion sensor but check in the docs for the integration as well as for the device itself. Many motion sensors have this since manufacturer’s understand that once motion is detected you want to consider a room/space occupied for a period of time longer then just “when the motion stops”.
If your motion sensor does not have this capability then proceed to step two - wrapping it in a trigger template sensor to add this capability. Which is done by basically copying and pasting this example from the docs. Except in this case our “event” is a state trigger, like so:
template:
- trigger:
platform: state
entity_id: binary_sensor.motion_detected
state: 'on'
binary_sensor:
name: Motion detected with occupancy timeout
state: 'on'
auto_off: '00:05:00'
This binary sensor turns on when your motion sensor does and then turns off again automatically 5 minutes after the last time motion was detected. Then basically ignore binary_sensor.motion_detected entirely, don’t reference it anywhere. Instead any time you want to write an automation/script that does something based on motion in the room use binary_sensor.motion_detected_with_occupancy_timeout.
Hmm a no motion trigger might indeed do the job. Rather then checking for motion for the last 5 minutes, i check if there was no motion. Have to think about this.
That’s great Mike, much obliged. Yeah my sonoff motion sensor does have the occupancy sensor. But isn’t that sort of the same as saying ‘no motion detected for x’ ?
I think i have a similar configuration for my binary PIR sensors, let me take a good look at what you suggested.
It is yes but unlike the automation trigger it gives you a way to check that later. You asked this:
If you use a trigger in an automation then as you note that has issues. Yes you can set it up so an automation fires when motion ceased 5 minutes ago. But you have no way to randomly check if there was motion in the last 5 minutes in a template or script.
With the entity you can. If this evaluates to true:
How can we make this through the web interface? If I understand correctly helpers are similar to adding these templates in the config.yaml file.
I tried adding this as a binary sensor or sensor template, through the template helper. Replacing the entity_id with that of my motion sensor, however the state for the helper remains off.
