I have a scene that sets certain colors on my exterior RGB Zigbee bulbs. Unfortunately, when I activate the scene, not all the bulbs change to the right colors (bulbs may be different than each other, e.g. Christmas colors).
At the moment, I just have a Node Red automation loop as part of a larger flow to just activate the scene 5 times with a 5 second delay between loops. This seems to work most of the time, and when bulbs are “missed” from the first activation, they may get picked up on subsequent ones.
However, I was hoping to find a more elegant solution to this rather than a dumb 5x loop, especially since sometimes 5x is not enough. Is there a way to validate each light/switch state and settings against what the scene expects?
Not sure if this helps, but I had a similar problem when I had too many devices on a Hue hub; the hub couldn’t keep up with all the individual commands coming from HA to set a scene.
2 possible solutions; I first used a 2nd Hue hub which split the workload, but eventually moved to Z2M and had the scene set there instead of HA (so HA issues a single command and Z2M split that into the individual bulb commands).
Oh I’m sure it’s a combination of the flaky hardware. SENGLED bulbs seem to work ok, but I’ve found that I can’t consistently get them to update when commands are sent. The loop works ok, but I guess I need to keep sending.
I asked the question since I can tell that the scene is not fully activated because the bulb rgb status in HA is accurate (still the old color). I was hoping there’s a builtin or easy way to keep activating the scene if any individual components were not at the expected state/config.
