Hi all,
I’m a bit stuck on how to do the following:
I’ve got a two-way switch connected to a shelly Ix3, so I basically have two boolean states.
Now, whenever I flip switch A, i’d like light A to toggle.
And, whenever i flip switch B, i’d like light B to toggle.
However, when i flip them both at the same time (which means within x milliseconds after each other), i’d like to do any other action, let’s call this action C.
For that, i was thinking something like:
When A is switched, check current state of B (Bstate1). Then after x milliseconds, check B again (Bstate2). If it hasn’t changed, this was a single A switch. If B is different then before (Bstate2 != Bstate1), then call action C.
Offcourse the same would apply for switch B in regards to A.
Anyone an idea on how to fix this in Node-Red?
