Check state of entity in a set timeframe and trigger automation
I want to check if a device is unavailable every day during a certain timeframe, and if it’s true would like to trigger HA to restart.
Note that I DON’T want to check if a state CHANGES within that timeframe. For my use case that change to “unknown” can also happen before. I basically just want to trigger the restart of HA only during that timeframe, not every time when there is a state change.
Will that do the trick?
  - platform: state
    entity_id:
      - switch.eve_energy_fdb7
    to: unavailable
condition:
  - condition: time
    after: "23:30:00"
    before: "23:45:00"
    weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sat
      - sun
  - service: homeassistant.restart
    data: {}
mode: single
- platform: time_pattern
  minutes: "/1"
condition:
  - condition: state
    entity_id: switch.eve_energy_fdb7
    state: unavailable
  - condition: time
    after: "23:30:00"
    before: "23:45:00"
    weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sat
      - sun
    data: {}
mode: single
Thank you petro. What does minutes: "/1" do? is it like for 1 minute?
it runs the automation every minute on the minute
Hi guys,
I would want to do something similar. I want to check if the state of a device was off for the past 5 minutes, and if so, turn off a smart plug where this is connected.
This condition, i want to be check only between 00:01 AM and 08:00 AM
Reason is that i have a device that in OFF mode has 40w consumption. In this case, i want turned off id is not used :slight_smile:
