I have a good number of complex flows that check the states of multiple entities. Right now I am doing this simply by stringing together current state nodes. Most of the time this works but recently I have noticed that on occasion the message is not making it through the second (or third, or fourth, etc) current state node to my call service node. Here is an example. Let me know if there is a better way to call a service based on multiple entities states.
[{"id":"c26117c1.22d9c8","type":"server-state-changed","z":"726d4ff.9337ab","name":"Matt Home","server":"9c6d9a8c.1f52f8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.matt_s_iphone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":180,"y":220,"wires":[["d064da2a.769228"],["2f5abb55.e96bc4"]]},{"id":"d064da2a.769228","type":"api-call-service","z":"726d4ff.9337ab","name":"Guest On","server":"9c6d9a8c.1f52f8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"input_boolean.guests","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":780,"y":220,"wires":[[]]},{"id":"2eae0e7a.28e732","type":"api-call-service","z":"726d4ff.9337ab","name":"Guest Off","server":"9c6d9a8c.1f52f8","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.guests","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":780,"y":380,"wires":[[]]},{"id":"ab7894ab.b90688","type":"server-state-changed","z":"726d4ff.9337ab","name":"Jan Home","server":"9c6d9a8c.1f52f8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.jan_iphone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":180,"y":180,"wires":[["d064da2a.769228"],["38a81f79.dc3d1"]]},{"id":"2f5abb55.e96bc4","type":"api-current-state","z":"726d4ff.9337ab","name":"Jan Away","server":"9c6d9a8c.1f52f8","version":1,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"device_tracker.jan_iphone","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":340,"y":360,"wires":[["a0488a2d.7441b8"],[]]},{"id":"38a81f79.dc3d1","type":"api-current-state","z":"726d4ff.9337ab","name":"Matt Away","server":"9c6d9a8c.1f52f8","version":1,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"device_tracker.matt_s_iphone","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":350,"y":420,"wires":[["9e15af60.d15cd"],[]]},{"id":"8e6a8b33.a1df48","type":"server-state-changed","z":"726d4ff.9337ab","name":"Bob Home","server":"9c6d9a8c.1f52f8","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"device_tracker.bob_iphone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"home","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":180,"y":260,"wires":[["d064da2a.769228"],["5753e2d2.c65d3c"]]},{"id":"a0488a2d.7441b8","type":"api-current-state","z":"726d4ff.9337ab","name":"Bob Away","server":"9c6d9a8c.1f52f8","version":1,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"device_tracker.bob_iphone","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":520,"y":360,"wires":[["2eae0e7a.28e732"],[]]},{"id":"9e15af60.d15cd","type":"api-current-state","z":"726d4ff.9337ab","name":"Bob Away","server":"9c6d9a8c.1f52f8","version":1,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"device_tracker.bob_iphone","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":520,"y":420,"wires":[["2eae0e7a.28e732"],[]]},{"id":"5753e2d2.c65d3c","type":"api-current-state","z":"726d4ff.9337ab","name":"Matt Away","server":"9c6d9a8c.1f52f8","version":1,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"device_tracker.matt_s_iphone","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":350,"y":480,"wires":[["18fff5a4.5ab94a"],[]]},{"id":"18fff5a4.5ab94a","type":"api-current-state","z":"726d4ff.9337ab","name":"Jan Away","server":"9c6d9a8c.1f52f8","version":1,"outputs":2,"halt_if":"not_home","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"device_tracker.jan_iphone","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":520,"y":480,"wires":[["2eae0e7a.28e732"],[]]},{"id":"9c6d9a8c.1f52f8","type":"server","z":"","name":"Home Assistant"}]
