Checking command HA is sending to Deconz
Since several months there is problem with transitions when turning off IKEA bulbs on Deconz, it’s ignoring the transition time. To debug this problem I want to check the PUT command HA is sending to Deconz. Where can I find it? In the logs from the Deconz Addon there is no command info.
developer tools > events > listen to events
event to subscribe to: deconz_event
start listening
Enable debug logging as detailed in the integration documentation and you can see all data sent to and from Deconz
Thanks! I will try this.
@kurtj : by listening to Deconz events you only see the yaml, not the commands to the API. Thanks anyway!
