Use Class 10 (32Gb minimum) SD card.
Real or Fake SD card? use “fakeflashtest.exe” to do a full test (read/write)
Correctly Partitioned SD card? - Use “Diskpart” to manage partitions.
Fully formatted SD card? use “SD Card Formatter” for do a full overwrite format.
Have a spare SD card of same make, class and size to do comparative tests.
Add a reset button or jumper to your R-pi so you can shut down without potentially corrupting the SD card.
Power supply 5.1 Volts/2.5A (measured as close as possible to the USB input) Use clean connector and correct thickness power cable. Use a scope on the power supply to watch for fast voltage drops-out during boot/downloads (your power supply could be failing only on higher current peaks!)
Never cut the power to your R-pi without holding reset first, (unless your really sure it is shutdown)
Avoid “hot plugging” your USB power, better to switch on using a external switch.
Use the HDMI monitor to see activity.
Use the correct WIFI settings on the CONFIG/My-network file.
Use Etcher or win32diskimger to flash your SD card.
Don’t pull out you card reader/writer until you are sure it has finished flashing.
Make sure you are installing the correct firmware for your R-pi hardware 3B, 3B+ (64), 4 etc
Make sure you are unzipping your downloaded image files before flashing (winrar etc)
Use your router’s traffic monitor to check for downloads activity (I use mikrotik winbox).
Make sure your WiFi router is set up correctly, I have solved install-download issues by re-loading the router config and re-booting.
Get used to the R-Pi green LED indicator and how it flashes, (Example: when I reset the R-pi, I know that it is ready to power off when it does 7 or so regularly spaced 1/2 second flashes).
Comments/edits welcome
Cheers
/P
