Recently Tado implemented the child-lock feature on their radiator valves. You can now turn on or off the child lock per radiator valve in the Tado application or website. When the child-lock is enabled, the set temperature can not be altered manually on the valve, this has to be done through the app/website/Home Assistant.
It would be nice to be able to turn on/off the child lock with a switch in Home Assistant, so we don’t have to use the Tado app on the side. There doesn’t seem to be much documentation on the Tado API, but it seems to involve some post request to https://my.tado.com/api/v2/devices/VAXXXXXXXXXX/childLock
(VA… is the valve ID). Here my knowledge ends
Any other Tado users who would like this feature to be accessible through Home Assistant?
