@Nimrod_Dolev
Thanks for getting back to me. I setup a script with the following YAML;
alias: Chime TTS Test
sequence:
- service: logger.set_level
custom_components.chime_tts: debug
- service: chime_tts.say
entity_id:
- media_player.breakfast_sonos
- media_player.kitchen_sonos
- media_player.livingroom_sonos
- media_player.roam_sl_sonos
- media_player.workshop_sonos
chime_path: fanfare
message: This is a test
tts_platform: tts.google_en_com
join_players: true
unjoin_players: true
mode: single
Monitoring execution of the script in the SONOS application, I see an audio file received and played by the breakfast_sonos speaker. None of the other speakers are joined together prior to the message being played. I tried running the script a couple of times.
Log entries follow;
2024-05-07 17:35:31.214 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration chime_tts which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-05-07 17:46:58.882 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called. Version v1.1.0-beta4 -----
2024-05-07 17:46:58.882 DEBUG (MainThread) [custom_components.chime_tts.queue_manager] Adding service call to queue
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ----- General Parameters -----
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * entity_ids:
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 0: media_player.roam_sl_sonos
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 1: media_player.workshop_sonos
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 2: media_player.kitchen_sonos
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 3: media_player.livingroom_sonos
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 4: media_player.breakfast_sonos
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * chime_path = fanfare
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * cache = False
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * offset = 450.0
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * final_delay = 0.0
2024-05-07 17:46:58.890 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * media_players_array:
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 0: {'entity_id': 'media_player.roam_sl_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 1: {'entity_id': 'media_player.workshop_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 2: {'entity_id': 'media_player.kitchen_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 3: {'entity_id': 'media_player.livingroom_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 4: {'entity_id': 'media_player.breakfast_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * message = This is a test
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_platform = tts.google_en_com
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_speed = 100.0
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_pitch = 0
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * announce = False
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * fade_audio = False
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * volume_level = -1
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * join_players = True
2024-05-07 17:46:58.891 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * unjoin_players = True
2024-05-07 17:46:58.892 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving audio from path: "custom_components/chime_tts/mp3s/fanfare.mp3"...
2024-05-07 17:46:59.581 DEBUG (MainThread) [custom_components.chime_tts] ...audio retrieved. Duration: 3.515s
2024-05-07 17:46:59.582 DEBUG (MainThread) [custom_components.chime_tts] - Generating new TTS audio with parameters:
2024-05-07 17:46:59.582 DEBUG (MainThread) [custom_components.chime_tts] * tts_platform = 'tts.google_en_com'
2024-05-07 17:46:59.582 DEBUG (MainThread) [custom_components.chime_tts] * message = 'This is a test'
2024-05-07 17:46:59.583 DEBUG (MainThread) [custom_components.chime_tts] * cache = False
2024-05-07 17:46:59.583 DEBUG (MainThread) [custom_components.chime_tts] * language = None
2024-05-07 17:46:59.583 DEBUG (MainThread) [custom_components.chime_tts] * options = {}
2024-05-07 17:47:00.452 DEBUG (MainThread) [custom_components.chime_tts] ...TTS audio generated in 870.0ms
2024-05-07 17:47:00.460 DEBUG (MainThread) [custom_components.chime_tts] - Saving mp3 file to folder: /media/sounds/temp/chime_tts/...
2024-05-07 17:47:00.751 DEBUG (MainThread) [custom_components.chime_tts.helpers.filesystem] - File saved to path: /media/sounds/temp/chime_tts/6ipc12at.mp3
2024-05-07 17:47:00.982 DEBUG (MainThread) [custom_components.chime_tts] - Chime TTS audio generated:
2024-05-07 17:47:00.983 DEBUG (MainThread) [custom_components.chime_tts] - audio_duration = 5.357
2024-05-07 17:47:00.983 DEBUG (MainThread) [custom_components.chime_tts] - local_path = "/media/sounds/temp/chime_tts/6ipc12at.mp3"
2024-05-07 17:47:00.983 DEBUG (MainThread) [custom_components.chime_tts] - public_path = None
2024-05-07 17:47:00.983 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id = "media-source://media_source/local/sounds/temp/chime_tts/6ipc12at.mp3"
2024-05-07 17:47:00.983 DEBUG (MainThread) [custom_components.chime_tts] *** Pre-Playback Actions ***
2024-05-07 17:47:00.983 WARNING (MainThread) [custom_components.chime_tts] Unable to join speakers. 0 supported media_players found (minimum is 2).
2024-05-07 17:47:00.983 DEBUG (MainThread) [custom_components.chime_tts] *** Chime TTS playback ***
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] 5 Sonos media players detected:
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] - media_player.roam_sl_sonos
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.roam_sl_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] - media_player.workshop_sonos
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.workshop_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] - media_player.kitchen_sonos
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.kitchen_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] - media_player.livingroom_sonos
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.livingroom_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] - media_player.breakfast_sonos
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.breakfast_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:47:00.984 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:47:00.985 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:47:00.985 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/6ipc12at.mp3
2024-05-07 17:47:00.985 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:47:00.987 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:47:00.987 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:47:00.987 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/6ipc12at.mp3
2024-05-07 17:47:00.987 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:47:00.988 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:47:00.989 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:47:00.989 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/6ipc12at.mp3
2024-05-07 17:47:00.989 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:47:00.990 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:47:01.004 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:47:01.004 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/6ipc12at.mp3
2024-05-07 17:47:01.004 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:47:01.017 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:47:01.017 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:47:01.017 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/6ipc12at.mp3
2024-05-07 17:47:01.017 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:47:01.029 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:47:01.029 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:47:01.029 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/6ipc12at.mp3
2024-05-07 17:47:01.029 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:47:01.034 DEBUG (MainThread) [custom_components.chime_tts] - Waiting 5.357s for audio playback to complete...
2024-05-07 17:47:06.396 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] - Waiting until 5 media_players aren't playing...
2024-05-07 17:47:06.396 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.roam_sl_sonos
2024-05-07 17:47:06.396 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.kitchen_sonos
2024-05-07 17:47:06.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.workshop_sonos
2024-05-07 17:47:06.799 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.livingroom_sonos
2024-05-07 17:47:07.000 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.breakfast_sonos
2024-05-07 17:47:07.001 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Completed in 8.11 s -----
2024-05-07 17:48:03.803 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called. Version v1.1.0-beta4 -----
2024-05-07 17:48:03.803 DEBUG (MainThread) [custom_components.chime_tts.queue_manager] Adding service call to queue
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ----- General Parameters -----
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * entity_ids:
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 0: media_player.roam_sl_sonos
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 1: media_player.workshop_sonos
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 2: media_player.kitchen_sonos
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 3: media_player.livingroom_sonos
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 4: media_player.breakfast_sonos
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * chime_path = fanfare
2024-05-07 17:48:03.807 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * cache = False
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * offset = 450.0
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * final_delay = 0.0
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * media_players_array:
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 0: {'entity_id': 'media_player.roam_sl_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 1: {'entity_id': 'media_player.workshop_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 2: {'entity_id': 'media_player.kitchen_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 3: {'entity_id': 'media_player.livingroom_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 4: {'entity_id': 'media_player.breakfast_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * message = This is a test
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_platform = tts.google_en_com
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_speed = 100.0
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_pitch = 0
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * announce = False
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * fade_audio = False
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * volume_level = -1
2024-05-07 17:48:03.808 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * join_players = True
2024-05-07 17:48:03.809 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * unjoin_players = True
2024-05-07 17:48:03.809 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving audio from path: "custom_components/chime_tts/mp3s/fanfare.mp3"...
2024-05-07 17:48:04.059 DEBUG (MainThread) [custom_components.chime_tts] ...audio retrieved. Duration: 3.515s
2024-05-07 17:48:04.061 DEBUG (MainThread) [custom_components.chime_tts] - Generating new TTS audio with parameters:
2024-05-07 17:48:04.061 DEBUG (MainThread) [custom_components.chime_tts] * tts_platform = 'tts.google_en_com'
2024-05-07 17:48:04.061 DEBUG (MainThread) [custom_components.chime_tts] * message = 'This is a test'
2024-05-07 17:48:04.061 DEBUG (MainThread) [custom_components.chime_tts] * cache = False
2024-05-07 17:48:04.061 DEBUG (MainThread) [custom_components.chime_tts] * language = None
2024-05-07 17:48:04.062 DEBUG (MainThread) [custom_components.chime_tts] * options = {}
2024-05-07 17:48:04.280 DEBUG (MainThread) [custom_components.chime_tts] ...TTS audio generated in 220.0ms
2024-05-07 17:48:04.288 DEBUG (MainThread) [custom_components.chime_tts] - Saving mp3 file to folder: /media/sounds/temp/chime_tts/...
2024-05-07 17:48:04.583 DEBUG (MainThread) [custom_components.chime_tts.helpers.filesystem] - File saved to path: /media/sounds/temp/chime_tts/s2lkndde.mp3
2024-05-07 17:48:04.832 DEBUG (MainThread) [custom_components.chime_tts] - Chime TTS audio generated:
2024-05-07 17:48:04.833 DEBUG (MainThread) [custom_components.chime_tts] - audio_duration = 5.357
2024-05-07 17:48:04.833 DEBUG (MainThread) [custom_components.chime_tts] - local_path = "/media/sounds/temp/chime_tts/s2lkndde.mp3"
2024-05-07 17:48:04.833 DEBUG (MainThread) [custom_components.chime_tts] - public_path = None
2024-05-07 17:48:04.833 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id = "media-source://media_source/local/sounds/temp/chime_tts/s2lkndde.mp3"
2024-05-07 17:48:04.833 DEBUG (MainThread) [custom_components.chime_tts] *** Pre-Playback Actions ***
2024-05-07 17:48:04.833 WARNING (MainThread) [custom_components.chime_tts] Unable to join speakers. 0 supported media_players found (minimum is 2).
2024-05-07 17:48:04.834 DEBUG (MainThread) [custom_components.chime_tts] *** Chime TTS playback ***
2024-05-07 17:48:04.835 DEBUG (MainThread) [custom_components.chime_tts] 5 Sonos media players detected:
2024-05-07 17:48:04.835 DEBUG (MainThread) [custom_components.chime_tts] - media_player.roam_sl_sonos
2024-05-07 17:48:04.836 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.roam_sl_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:04.836 DEBUG (MainThread) [custom_components.chime_tts] - media_player.workshop_sonos
2024-05-07 17:48:04.836 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.workshop_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:04.836 DEBUG (MainThread) [custom_components.chime_tts] - media_player.kitchen_sonos
2024-05-07 17:48:04.836 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.kitchen_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:04.836 DEBUG (MainThread) [custom_components.chime_tts] - media_player.livingroom_sonos
2024-05-07 17:48:04.837 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.livingroom_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:04.837 DEBUG (MainThread) [custom_components.chime_tts] - media_player.breakfast_sonos
2024-05-07 17:48:04.837 DEBUG (MainThread) [custom_components.chime_tts] sonos_media_player_dict = {'entity_id': 'media_player.breakfast_sonos', 'platform': 'sonos', 'should_change_volume': False, 'initial_volume_level': 0.01, 'playback_volume_level': -1, 'group_members_supported': True, 'announce_supported': True, 'is_playing': False}
2024-05-07 17:48:04.837 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:48:04.837 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:48:04.837 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/s2lkndde.mp3
2024-05-07 17:48:04.838 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:48:04.846 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:48:04.846 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:48:04.846 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/s2lkndde.mp3
2024-05-07 17:48:04.846 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:48:04.848 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:48:04.848 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:48:04.848 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/s2lkndde.mp3
2024-05-07 17:48:04.848 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:48:04.851 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:48:04.852 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:48:04.852 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/s2lkndde.mp3
2024-05-07 17:48:04.852 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:48:04.853 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:48:04.853 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:48:04.853 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/s2lkndde.mp3
2024-05-07 17:48:04.853 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:48:04.855 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-05-07 17:48:04.855 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-05-07 17:48:04.855 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/s2lkndde.mp3
2024-05-07 17:48:04.855 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.breakfast_sonos']
2024-05-07 17:48:04.871 DEBUG (MainThread) [custom_components.chime_tts] - Waiting 5.357s for audio playback to complete...
2024-05-07 17:48:10.243 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] - Waiting until 5 media_players aren't playing...
2024-05-07 17:48:10.243 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.roam_sl_sonos
2024-05-07 17:48:10.243 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.kitchen_sonos
2024-05-07 17:48:10.444 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.workshop_sonos
2024-05-07 17:48:10.646 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.livingroom_sonos
2024-05-07 17:48:10.848 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player] ✔ media_player.breakfast_sonos
2024-05-07 17:48:10.849 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Completed in 7.04 s -----
Here’s an image of the SONOS App prior to running the script.
Here’s an image of the SONOS App after running the script.
You can see that Breakfast SONOS played the chime and the message however no other SONOS speakes were joined with it.
