Hi @Nimrod_Dolev ,
This is my Chime TTS config
and this is the debug log message
I hope you can find the reason.
Kris
Hi @Nimrod_Dolev ,
Kris
Thanks Kris.
Please try changing the chime_tts.say_url
folder path in the configuration to:
/config/www/chime_tts
Yes! That worked. I didnāt realize that it wasnāt already there because of signing up with cloud, but its there now, and it works. Thanks very much. Its been working great for my google speaker, so looking forward to putting it to use with the alexas. Thanks again for all your hard work! Can someone remind me how to mark this as a solution?
Great! Glad it worked out! Thank you as well
Hi @sri4iot. I can certainly add the ability to crossfade segments, but crossfading will quieten the overlapping audio.
Please be aware that you can already overlap segments over each other via the offset property when providing a negative value.
Hey @Nimrod_Dolev , have you gotten a chance to take a look at this?
About six months ago volume support for Sonos devices was added to Chime TTS and confirmed as working. I donāt own any Sonos devices myself, so I canāt confirm personally, but perhaps other Sonos users can report here whether theyāre also having issues?
Can you please check if you can successfully call the Home Assistant media_player.play_media
action to your Sonos speakers with the volume parameter? If you can, please provide me with the YAML you used?
Another user had the same issue and was able to resolve it by updating the Sonos firmware via the Sonos app.
The integration is working great for me, Iām using v1.1.6-beta5, the only issue is that I need to set cache: true
otherwise the file get deleted, I already reported the issue to the repo.
Iām using HomePods and Alexas, and I love how this integration converts the MP3 to a format Alexa can play. Great work! For TTS, Iām using OpenAI.
Iām also using mini-media-player
, this is how it can be configured
type: entities
entities:
- type: custom:mini-media-player
entity: media_player.kids_bedroom
group: true
source: icon
info: short
hide:
power: true
controls: true
tts:
platform: service
service: chime_tts.say
service_data:
cache: true
message: text
entity: media_player.echo_pop
group: true
source: icon
info: short
hide:
power: true
controls: true
tts:
platform: service
service_data:
audio_conversion: Alexa
cache: true
message: text
title: Wild Robot
@Nimrod_Dolev. Thanks for the direction. With -1500 Offset value I am able to hear the music before the TTS finishes.
using the media_player.play_media
action the volume parameter seems to work see YAML below
action: media_player.play_media
entity_id: media_player.living_room
announce: true
media_content_type: "music"
media_content_id: "http://192.168.8.85:8123/media/local/sounds/temp/chime_tts/__761ynx.mp3"
extra:
volume: 50
I did try updating my system but it was already up to date.
Thanks @pabla. I donāt yet understand why the volume_level
parameter isnāt changing the volume for your Sonos media_player, given that under the hood of Chime TTS, I am using the same action call to media_player.play_media with the extra volume parameter, like in your YAML example.
Can you please upgrade to the latest version, v1.2.0, and let me know if the issue still occurrs for you?
Hi @Nimrod_Dolev, Iām curious if this integration supports the following functionalities:
Iād like to select and play a random MP3 file from a list, either using media-source
or direct URLs. Hereās an example:
chime_path: >-
"/media/ringtone/morning.mp3",
"/media/ringtone/cheer.mp3",
] | random }}
Iām trying to use Jinja2 macros to dynamically generate TTS messages. This works on Google Translate but doesnāt seem to function as expected in this integrationāit only processes static text.
For example, I have a macro defined in time.yaml
{%- macro time() -%}
{{ ["It's ", "Now is "] | random }} {{ now().hour }}
{%- endmacro -%}
Iād like to use this macro in my action like this:
action: chime_tts.say
entity_id: media_player.speaker
message:
- tts: !include speech/time.yaml
- delay: 1000
FYI, I just updated to 1.2.0 and after restart, HA tells me:
The integration
chime_tts
could not be found. This happens when a (custom) integration was removed from Home Assistant, but there are still configurations for thisintegration
. Please use the buttons below to either remove the previous configurations forchime_tts
or ignore this.
I still see Chime in HACS. It says itās installed. I also get 14 errors in all automations that use it. Iām not seeing anything in the logs.
BTW, this is how I use chime_tts in my automations:
actions:
- target:
entity_id: media_player.kitchen_display
delay: 450
tts_playback_speed: 100
chime_path: /media/sounds/temp/chime_tts/soft.mp3
message: The dryer is done
tts_platform: google_translate
language: en
volume_level: 1
cache: true
But it doesnāt always fire off. And when it does, it gives the HA chime, then waits 10 seconds then give the soft chime and then it talks.
unfortunately no luck with v1.2.0. Does it have something to do with the fact that chime tts sends volume as a decimal number while the media_player.play_media
action sends it as a number from 0-100?
Hey Paul. I havenāt had this happen before so I donāt know what the answer is for your missing integration - but can you please try removing the integrarion (if it is in your list of added integrations) and adding it again?
Regarding the playback: you mentioned that you first heard a HA chime and then the announcement for Chime TTSā¦Iām not clear on what you mean here. What is the HA chime?
Chime TTS converts the audio_volume
float 0-1 value to an int value between 0-100 for Sonos media_player devices, so thatās not the issue.
Perhaps you could please enable debug logging and supply time with the debug logs so that I might better understand what might be going on?
I deleted Chime_tts integration.
I redownloaded Chime_tts from HACS
I restarted HA
Chime_tts is shown installed in HACS
I try to add integration Chime_tts but it isnāt found.
When I type search term: āchimeā I see no responses.
Hmmmm
I still donāt understand why this is happening. Perhaps try making sure you have completely removed the integration and its data file before reinstalling it again by deleting Chime TTS integrationās:
/config/custom_components/chime_tts
/config/.storage/chime_tts_integration_data
