China LED Bulb
Hi all,
i bought 2 China LED Bulbs RGBW (https://www.aliexpress.com/item/32978215599.html) managed by MAGIC HOME LITE app (https://apps.apple.com/it/app/%E9%AD%94%E6%B3%95%E5%AE%B6lite/id1399499332).
They work perfectly with app and Alexa skill too but i can’t setup them in my Home Assistant.
I tried with flux_led platform but they were not recognized.
They should use the broadlink wifi chip.
Can someone help me?
Thnx in advance,
Enzo
Try tuya component
The Echo/Alexa interface protocol is Zigbee if that helps.
Yes i know but in my case i’m using the small echo dot (without zigbee hub) with Alexa " MAGIC HOME LITE" Skill https://www.amazon.it/Magic-Home-Lite-for-EU/dp/B07GBWGJ71
Tuya component needs a Tuya account but i don’t have it.
Anyway i installed the Tuya App, registered an account and tried to setup the light but it has not been recognized.
Can i use ZigBee protocol to try to discovery the China LED Bulbs?
Can it works?
Did you figure this out?
Unfortunately no, i’m using Alexa and owner app to switch on/off and color changing
Could you finally integrate them into Home Assistant?
I got this lamp https://aliexpress.ru/item/4000252893280.html?spm=a2g0s.9042311.0.0.403833edaFeotC https://play.google.com/store/apps/details?id=com.broadlink.lite.magichome&hl=ru I wanted her to work in hassio in the debian os, but nowhere in the integrations did I find a package for her. Is it possible to connect it without an application from the manufacturer on the local network?
@Aleksahek here took care of it GitHub - sahilchaddha/homebridge-magichome-platform: Homebridge Plugin for MagicHome LED Strips with Preset Scene Automation Support (Cycle Color/Fade/Strobe) I think knowledgeable people will just do it or not?
